External fans July 26, 2014 02:44AM |
dc42
Paul, if you want really good speed control then you should get a 4-wire PWM fan (cheap as chips on eBay and Amazon). Wire the fan between +12V and ground (you can use the positive fan output on the Duet for the +12V). Then wire the fan PWM input to the anode of a 1N4148 or similar diode, and the cathode of that diode to the negative fan output pin on the Duet. You'll need to select inverse PWM in the M106 command. A fan meeting the Intel PWM fan specification has to go down to 30% PWM or lower.
Re: External fans July 26, 2014 04:20AM |
Re: External fans July 26, 2014 04:58AM |
Re: External fans July 26, 2014 06:17AM |
appjaws1
However I forgot to issue "M106 l" -- is that the correct command to select inverse PWM?
M106 I1 S89 ; set fan PWM to 35%
appjaws1
What does it do? Why does PWM need to be inverse. I think the "S" and "P" parameters should be controlled by the settings in slic3r, so do I need to do anything with them?
Re: External fans July 26, 2014 07:00AM |
Re: External fans July 26, 2014 07:26AM |
Re: External fans July 26, 2014 04:08PM |
Re: External fans July 26, 2014 05:05PM |
Re: External fans July 26, 2014 05:13PM |
Re: External fans July 26, 2014 05:33PM |
Re: External fans July 26, 2014 06:02PM |
Re: External fans July 26, 2014 06:08PM |
Re: External fans July 27, 2014 06:24AM |
Re: External fans July 27, 2014 06:44AM |
Re: External fans July 27, 2014 03:09PM |
dc42
Paul, can you provide a photo showing where you have mounted the two fans? I'd like to improve the print cooling when I am using the dual head.
Re: External fans July 30, 2014 06:47PM |
Re: External fans July 31, 2014 05:02AM |
MrCrispi
I'm also really interested in this Paul as I have been playing with various forms of additional cooling fans to help avoid curling on thin overhangs,with varying success, so if you are getting good results It would be great to see some finished .stl or scad files and fan specs.
Re: External fans August 28, 2014 12:23PM |
Re: External fans August 28, 2014 12:50PM |
appjaws1
I bought a 2N7000 mosfet and wired source to ground (i.e. fan black wire), gate to fan output -ve terminal, drain to fan brown wire and it didn't work.
I think I have a terminology understanding problem.
the fan has 4 wires, red, black, brown and yellow
the duet with expansion board has the fan output +ve and -ve and a ground pin, the 5th one along.
so leaving out yellow for the time being, I connected the fan black wire to the 2N7000 source and to the duet ground pin.
the gate to the duet fan -ve pin and the drain to the fan brown wire.
The fan red wire to the duet fan out +ve terminal
Re: External fans August 28, 2014 02:13PM |
dc42
- With M106 S0 (note: you do not want to invert the PWM as the mosfet does that already), you should have almost 12V on the gate and 0V on the drain. The fan LED on the Duet should be off..
dc42
- With M106 S255 you should have 0V on the gate and a few volts on the drain, provided the fan black and red wires are connected correctly. The fan LED on the Duet should be on.
Re: External fans August 28, 2014 02:31PM |
Re: External fans August 28, 2014 02:56PM |
Re: External fans August 28, 2014 04:44PM |
Re: External fans August 28, 2014 05:09PM |
gnarly
Paul, did you find:
[db.sanyodenki.co.jp]
it has a graph showing the expected range of PWM vs RPM.
(I've just replaced some similar fans to make an old Dell 1U high server use some bigger and quieter fans.)
Those fans are a bit unusual...
- they are designed for high static pressure
- they are very high speed (and so noisy)
- their power consumption is rather high for a fan.
you could always change the speed by changing the voltage to the fan
e.g. put a low value resistor in series with the fan to reduce the voltage and hence the top speed.
(the resistor will need to be suitably sized for wattage too)
Dave
Re: External fans August 28, 2014 05:29PM |
Re: External fans August 28, 2014 05:38PM |
Re: External fans August 28, 2014 05:55PM |
dc42
Re: External fans August 29, 2014 06:33AM |
MrCrispi
dc42
Hi Paul, any chance you could publish a couple of pictures of your set up with your extra fans? I'm struggling to picture the mods needed to the arms to make it fit, and seeing it In place would really help
Many thanks
Re: External fans August 29, 2014 08:21AM |
Re: External fans August 29, 2014 09:33AM |
