Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board May 13, 2015 05:15PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board May 20, 2015 06:45AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 10, 2015 02:41PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 10, 2015 04:01PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 07:14AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 08:06AM |
Ormerod187
Hi dc42,
it was not a good start because I did not clean the extruder....
but you sensor board.... absolutely...it's the best!
[youtu.be]
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 08:16AM |
dc42
Ormerod187
Hi dc42,
[youtu.be]
Thanks!
I have my homez and homeall files set to not drop the head to Z=0 after the G30 command, so that any filament oozing from the nozzle is unlikely to be deposited in the centre of the bed. Then I have the slic3r start gcode set to move the head to the edge of the bed while warming up. The result is than any ooze from the nozzle gets deposited on the skirt, where it is usually harmless.
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 08:18AM |
dc42
...where it is usually harmless.
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 08:25AM |
Treito
dc42
Hi dc,
I have other experiences like that. The ooze gets stuck on the skirt but during the printing of the first layer it may happen that the head or parts of the hot end hits the ooze and got lifted and your first layer is trash. That is way I clean the nozzle before start printing or - it is a small part - put the skirt far far away. An option would be nice to print the skirt outside and not aligned around the part.
Dario, you print directly on glass? With PLA? I am sometimes able to do this but it often fails. How do you do this? Bed temperature? PLA manufacturere? PLA temperature? Or is this maybe caused by the heat spreader?
Sven
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 08:48AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 09:38AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 10:06AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 10:27AM |
Treito
Probably it is a leveling problem. But ABS will not stick on glass even though HIPS seems to be better than PLA sticking on pure glass. But damn it I took a look on your table some hours ago because I am considering buying esun filament and the result on the table prevent me so I think I keep at Kiloplast even though I did not test PLA. This is going to be a little bit off-topic.
I like the light. (I love English - took -look; like -light). Is it only one color or can you play with the color?
Dario, I do not like this digital calipers. I had one and after zeroing and using it once it had an offset again of 0.02. Do you have any loose belt? I only get undersized models by 0.2mm in that dimensions. You should consider trying Slic3r 1.2.7.
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 10:51AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 13, 2015 04:04PM |
Ormerod187
Agree .....you are right
normally when I starting the extruder is empty but move the head to the edge of the bed it's the best
Thanks
Dario
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 14, 2015 07:43AM |
dc42
Ormerod187
Hi dc42,
[youtu.be]
Thanks!
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 03:36PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:02PM |
Treito
Hello,
I have one stupid question. I probably know the answer but it is worth to try it although it will not work.
Does your sensor board works even with a black surface? I try to use this BuildTak even though it did not convince me yet. The problem is that I have only a small amount to calibrate the Z-axis in detail there is a small advertising logo (Why I do so much money for this and have advertisement) and I am using the text respective the letter "P" for homing, because it is white. But auto bed leveling for example does not work and something is instable with my bed leveling at the moment. my last chance is that your different sensor even works on the black surface (there is a small amount of reflection) but I think it will not doing this.
Regards,
Sven
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:07PM |
Darathy
DC42's instructions actualy say you have to put a sheet of black paper under the glass or use BuildTak to improve accuracy.
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:09PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:17PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:40PM |
Treito
DC42 what about the prices, availibility and shipping? In worst case I have to built them by my own. The complete equipment would be here.
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 04:52PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 05:19PM |
Darathy
Question from me. Can i use kapton over the glass with your sensor? will it work normaly?
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 05:58PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 06:28PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 21, 2015 06:39PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 23, 2015 12:42PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 23, 2015 01:59PM |
Darathy
Hey ,i have a question: Above which hight should your probe be reading 0 all the time? i have my hot end flat againt the hot bed and still have 0 ,if i push it down by 0.1 it jumps to 530. Another strange thing is i got it to home normaly 1st time i tried it during your comissioning section but 2nd time it just slamed against the threaded rod(lucky for the plastic sheild!) i even extended the pad with white cardboard and still slamed the red light turned red when over the pad aswell, How much space should there be between the pad and the sensor?
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 24, 2015 07:56AM |
