Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 24, 2015 08:21AM |
Treito
Can I use IR-LEDs and photo transistors with a viewing angle of 30°? I have an offer for a cheap variant.
How does it work with the output because the Duet awaits an analogue signal? Does the Mini sensor board use PWM and this works?
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 24, 2015 10:56AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 24, 2015 11:28AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 25, 2015 08:08AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 25, 2015 09:10AM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 25, 2015 04:03PM |
dc42
Darathy
Hey ,i have a question: Above which hight should your probe be reading 0 all the time? i have my hot end flat againt the hot bed and still have 0 ,if i push it down by 0.1 it jumps to 530. Another strange thing is i got it to home normaly 1st time i tried it during your comissioning section but 2nd time it just slamed against the threaded rod(lucky for the plastic sheild!) i even extended the pad with white cardboard and still slamed the red light turned red when over the pad aswell, How much space should there be between the pad and the sensor?
The trigger height of the board when used above plain glass will be between 2.5 and 3.5mm. I write the value I measure during testing on the board, to the nearest 0.25mm. The trigger height above white paper is slightly greater.
If the board reading is still 0 when the nozzle is touching the glass, that suggests to me that either the board is mounted too high, or that you have a highly-reflecting surface underneath the glass, for example you are using a mirror as the print bed. The board should be mounted so that the bottom edge is between 1mm and 2mm higher than the tip of the nozzle. The clearance between the bottom edge of the board and the sensor pad should likewise be about 1mm to 2mm.
If the board is much too high above the sensor pad, please check that you have your nozzle mount installed the right way up, as described in the instructions.
Hope this helps - David
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 25, 2015 06:52PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 26, 2015 02:04PM |
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 26, 2015 02:12PM |
Darathy
the glass is 3mm but i put a peice of paper which i printed all black and now it sees 535 at 3.35mm and homes Z perfectly! Thank you
Re: Reminder for new owners: Better Z-probe/fan control/hot end illumination board June 27, 2015 11:34AM |
