Anyway to get the heatbed heat faster? July 28, 2014 12:57AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 02:46AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 05:26AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 06:02AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 08:12AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 08:38AM |
antlvk
Upgrading to this power supply is it directly power to the Duet?
Re: Anyway to get the heatbed heat faster? July 28, 2014 10:16AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 10:37AM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 01:55PM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 02:29PM |
Re: Anyway to get the heatbed heat faster? July 28, 2014 02:42PM |
antlvk
means everything that connected to the due board also have more voltage.... ok.... next project.
Re: Anyway to get the heatbed heat faster? July 29, 2014 10:31AM |
Re: Anyway to get the heatbed heat faster? July 30, 2014 12:38AM |
Re: Anyway to get the heatbed heat faster? July 31, 2014 02:41PM |
Re: Anyway to get the heatbed heat faster? August 17, 2014 05:55AM |
Re: Anyway to get the heatbed heat faster? August 17, 2014 06:47AM |
Re: Anyway to get the heatbed heat faster? August 18, 2014 07:40AM |
Re: Anyway to get the heatbed heat faster? August 18, 2014 07:56AM |
Re: Anyway to get the heatbed heat faster? August 18, 2014 08:24AM |
dc42
Some folks on this forum who print ABS have said that they put a heat-insulating mat on top of the heated bed while it heats up.
Re: Anyway to get the heatbed heat faster? March 16, 2015 07:48PM |
Re: Anyway to get the heatbed heat faster? March 17, 2015 05:44AM |
Re: Anyway to get the heatbed heat faster? March 18, 2015 11:34AM |
Re: Anyway to get the heatbed heat faster? March 18, 2015 02:39PM |
ChristofSchwiening
I have just modified my Ormerod 2 to allow for faster heating. I have removed the MDF/wood rectangle that makes-up the bed support as well as the aluminium heat spreader. Doing this makes the bed a lot lighter and it reduces the thermal mass considerably. I have then used an aluminium foil blanket (just a folded rectangle) to cover the bed during heating. The result is that the glass bed (with the standard power supply) heats up to 115 degrees in 10 mins....
Re: Anyway to get the heatbed heat faster? March 20, 2015 12:33PM |
Re: Anyway to get the heatbed heat faster? March 20, 2015 03:12PM |
ChristofSchwiening
I guess I need to break open the power supply and see if there is a pot to tweak!
Re: Anyway to get the heatbed heat faster? March 30, 2015 10:43AM |
