Filament gets stuck / doesnt move forward August 05, 2014 04:06PM |
Re: Filament gets stuck / doesnt move forward August 05, 2014 05:59PM |
Re: Filament gets stuck / doesnt move forward August 05, 2014 06:41PM |
Re: Filament gets stuck / doesnt move forward August 05, 2014 09:17PM |
Re: Filament gets stuck / doesnt move forward August 06, 2014 03:03AM |
djar
Any idea what could cause that or how to fix it?
Re: Filament gets stuck / doesnt move forward August 06, 2014 04:44AM |
Re: Filament gets stuck / doesnt move forward August 06, 2014 12:26PM |
Re: Filament gets stuck / doesnt move forward August 06, 2014 12:46PM |
Re: Filament gets stuck / doesnt move forward August 06, 2014 01:13PM |
dc42
In my case, the hobbed part was completely clean, so that wasn't the explanation. I think the problem was the combination of under-diameter filament and extra friction due to the filament wearing a groove in the extruder body. I think RRP ought to redesign the extruder drive filament inlet to take a PTFE tube liner all the way round the 90 degree bend. With this change, it probably isn't necessary to spring-load extruder drive, although that is still a nice-to-have.
I am of course assuming that the filament wouldn't wear through the PTFE anything like as fast as it wears through the extruder body. Even if there is some wear, replacing the PTFE tube would be much easier than printing and building a new extruder drive.
Re: Filament gets stuck / doesnt move forward August 06, 2014 04:22PM |
Re: Filament gets stuck / doesnt move forward August 07, 2014 08:13AM |
dc42
Re: Filament gets stuck / doesnt move forward August 07, 2014 10:15AM |
droftarts
dc42
It's on the 'to do' list! Just rather busy, at the moment... There's always a list of parts to tweak, it's just what can be done without causing other problems (ie documentation), and what gets rolled out as part of a larger update.
Ian
RepRapPro tech support
Re: Filament gets stuck / doesnt move forward August 08, 2014 01:44AM |
dmould
As said, an STL was posted for such an extruder a while ago - I printed it and it is working well. I cannot recall who posted it.
Dave
(#106)
[forums.reprap.org]Quote
Mr.Burns
..I've modified the filament guide, so now its possible to put in the pfte-tube about 40mm. It will now guide the filament as far as possible. I extruded the block in the area of the gone housing a little bit,too.
Furthermore, i put a flap under the gap, where the retaining tongue has to secure the bowden cable. Now its possible to fix the tongue with a M3 screw and a Hex nut or in a simple way with a cable tie. I also dthe high of the gap for the retaining tongue a little, so the tongue will fit in exactly...
Re: Filament gets stuck / doesnt move forward August 10, 2014 12:35PM |
