Re: Anyone interested in an LCD control panel for the Ormerod? September 24, 2014 10:42AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 24, 2014 11:20AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 25, 2014 08:55PM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 02:25AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 07:57AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 08:16AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 08:36AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 08:44AM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 26, 2014 08:47PM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 27, 2014 08:18AM |
KimBrown
Next time you print, take a close look at how much the PTFE tube moves
[forums.reprap.org]Quote
dc42
Bear in mind that there are other factors at play here. Someone (I forget who) pointed out that if you hang the extruder on the middle slot of the X axis, the Bowden tube exerts a stronger outward (and hence downward) force on the print head at the centre of the X-axis range than near the ends. The amount that the glass domes up in the middle depends on how firmly it is clamped at the corners, which you can adjust.
KimBrown
...It becomes alive. The pillow has stiffend it, but allows it to have it's freedom.
I think the tube has a great deal of explaining to do concerning finish...
Re: Anyone interested in an LCD control panel for the Ormerod? September 30, 2014 03:53PM |
Re: Anyone interested in an LCD control panel for the Ormerod? September 30, 2014 08:25PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 01, 2014 02:01AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 01, 2014 03:32AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 01, 2014 01:18PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 01, 2014 03:48PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 02, 2014 02:28PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 02, 2014 03:52PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 03, 2014 06:47AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 03, 2014 07:16PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 04, 2014 10:29AM |
dmould
I wrote my "Boss" module for example after finding that that shape worked best for self-tapping screws. If the wall is too thick the screw cannot deform it outwards when it cuts its threads and there is a greater risk of shearing off a column at a relatively weak layer bond - as there is with a thin wall that does not have the reinforcing ribs.Dave
dmould
After looking at appjaws' SCAD I took a look at the library "boxes,scad" that ships with Openscad to see why it was taking so long to render. That library has a rather convoluted and slow method of making a rounded box. All I do is place a sphere in each corner of the required box (offset by the radius) and perform a "hull" operation on them. A couple of cubes may be added to get completely accurate dimensions, especially for low values of $fn. It's faster, and also allows the box to have draft (slightly angled sides) for use in conventional injection processes - just move the top spheres out a bit. If you only need rounded side edges, use cylinders instead of spheres.
Dave
Re: Anyone interested in an LCD control panel for the Ormerod? October 04, 2014 11:43AM |
appjaws1
I have made my own roundbox.scad from your code and can't believe how quick it renders compared to the round box in the supplied library, so I hope you don't mind if I use it in future.
Great lines of code, where can I get some information on writing code to your standard? One of the best pieces I have learnt is the use of the for loop, which I have used to define mounting standoffs in the 4 corners of the box.
Any information of how I can improve my code and examples of good code will be gratefully received.
Paul
Re: Anyone interested in an LCD control panel for the Ormerod? October 04, 2014 11:46AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 04, 2014 12:16PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 04, 2014 12:35PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 05, 2014 07:10PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 01:26AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 03:48AM |
appjaws1
Looking good David. In the future, seeing that their is a lot of free space, would it be feasible to display a picture of the gcode model? or is that too ambitious?
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 06:01AM |
dc42
Sadly, there is little chance of that, because there is only 6K flash memory left and I still have a lot of things still to implement e.g. the touch driver and the menu system. I can save some more memory in the TFT driver by disabling portrait mode, and I can get rid of the smaller font; but even so I expect memory to be tight. It's tempting to use a larger processor, such as the atxmega64a4u; however the idea was to make the unit compatible with an Arduino Leonardo so that users can easily modify the firmware.
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 07:50AM |
