Unresponsive web interface August 08, 2014 06:58AM |
Re: Unresponsive web interface August 08, 2014 07:17AM |
Re: Unresponsive web interface August 08, 2014 07:25AM |
Re: Unresponsive web interface August 08, 2014 07:39AM |
Re: Unresponsive web interface August 08, 2014 08:00AM |
Re: Unresponsive web interface August 08, 2014 08:16AM |
Re: Unresponsive web interface August 08, 2014 08:47AM |
bitfield
Now, when the final layers of the whistle was printing I accessed the web interface from another client (my phone). First the page loaded fine and then it all froze and when I went to the printer to see what happened it was at a complete stop and inaccessible. Had to cut the power. It's not like it happens seldom but very often so I can't be the only one experience this, right?
Re: Unresponsive web interface August 08, 2014 10:11AM |
bitfield
Re: Unresponsive web interface August 08, 2014 01:53PM |
Re: Unresponsive web interface August 23, 2014 02:12PM |
Re: Unresponsive web interface August 23, 2014 02:46PM |
bitfield
I have just completed my first Ormerod build and successfully printed the snowman (more or less). Some adjustments need to be done of course. But what I do find is the web interface being extremely unreliable. Currently it's being more or less completely unresponsive. Sometimes I'm able to open up the web interface and hit the connect button but soon after it freezes and when I try to reload the page it's like the other end isn't responding. I'm still able to use pronterface when this happens though.
I've made sure the assigned IP address does not collide with anything else. What could be the cause of this?
Re: Unresponsive web interface August 23, 2014 03:02PM |
Re: Unresponsive web interface August 26, 2014 10:29AM |
Re: Unresponsive web interface August 26, 2014 11:37AM |
Re: Unresponsive web interface August 26, 2014 11:47AM |
zombiepantslol
There is still a networking issue in RRP's and dc42's firmware forks, and it's possible this issue is somehow related. My firmware fork already contains a potential fix, so it would be interesting to know if this issue also occurs with my latest firmware release. Is anyone willing to give it a try and report if this problem persists? If it does, I'd appreciate a Wireshark dump so I can take a look again.
Re: Unresponsive web interface August 26, 2014 11:51AM |
Re: Unresponsive web interface August 26, 2014 06:08PM |
Re: Unresponsive web interface August 26, 2014 06:15PM |
zombiepantslol
Re: Unresponsive web interface August 27, 2014 04:22AM |
Re: Unresponsive web interface August 27, 2014 04:26AM |
Re: Unresponsive web interface August 27, 2014 04:56AM |
ezwul
Hi 3D
When you capture the traffic in wireshark you can apply a filter, for example "eth.addr == 00:15:17:7a:50:48" and this should only capture traffic from/to this device and leave your company traffic out of the capture. Obviously, substitute your printers MAC address and not the one above for my PC
Re: Unresponsive web interface August 27, 2014 06:07AM |
Re: Unresponsive web interface August 28, 2014 02:07PM |
Re: Unresponsive web interface August 28, 2014 07:10PM |
Re: Unresponsive web interface August 29, 2014 02:39AM |
From: "Gaudineer, Kevin" Date: Thu, 9 Jan 2014 16:43:01 +0000 Have the ‘Save Capture File’ option’s been changed or moved to another menu? I have downloaded and installed WireShark 1.10.5 (32 bit for Windows XP) and captured a file. I used a display filter to only show the packets I was interested in (tcp.stream eq 0) and then tried to save the filtered display. When I select File -> Save As I only get the typical windows file save as dialog box the Wireshark file save as used to have choices like displayed packets or all captured packets or a range of packets All of those options are now gone on my screen.
From: Evan Huus Date: Fri, 10 Jan 2014 11:07:04 -0500 Yes, the advanced options for saving only filtered packets or only particular ranges are now under "File -> Export Specified Packets" instead. Evan
