ormerod-2?? August 16, 2014 10:20AM |
Re: ormerod-2?? August 16, 2014 11:54AM |
Re: ormerod-2?? August 16, 2014 02:29PM |
Re: ormerod-2?? August 16, 2014 03:00PM |
Re: ormerod-2?? August 16, 2014 03:41PM |
Re: ormerod-2?? August 16, 2014 04:46PM |
dc42
- Duet board looks the same, however the 5V supply is now provided by an external linear regulator
Re: ormerod-2?? August 17, 2014 02:26AM |
Re: ormerod-2?? August 17, 2014 03:42AM |
Re: ormerod-2?? August 17, 2014 04:35AM |
Davek0974
Looks good, is that your latest excellent IR probe DC42?
Davek0974
I guess there won't be many more aluminium bed supports needed anymore.?
Davek0974
6mm ply is whole lot better than the mdf offering, but why not go straight for an alu one?
Re: ormerod-2?? August 17, 2014 09:46AM |
Re: ormerod-2?? August 17, 2014 09:56AM |
dc42
Perhaps RRP's laser cutter can't handle aluminium. It's much harder to cut than wood or acrylic because it reflects the laser light very well.
Re: ormerod-2?? August 17, 2014 04:41PM |
Re: ormerod-2?? August 17, 2014 05:30PM |
Re: ormerod-2?? August 18, 2014 04:25AM |
Re: ormerod-2?? August 18, 2014 06:42AM |
droftarts
The acrylic we use now IS 5mm. The earlier stuff we used was more variable; it's the difference between using cast and extruded acrylic, and we haven't had any problems with variation in thickness since we swapped to extruded, which was after the first 500 red kits.
Re: ormerod-2?? August 19, 2014 05:31AM |
Re: ormerod-2?? August 19, 2014 05:58AM |
dc42
"The extruder has much easier access for cleaning; it has a locked drive stack that improves reliability"
Re: ormerod-2?? August 19, 2014 08:33AM |
Re: ormerod-2?? August 19, 2014 10:50AM |
Re: ormerod-2?? August 19, 2014 11:21AM |
dmould
It should be easy to file off the lip for those of us who wish to update our existing Ormerod with a new extruder housing.
Re: ormerod-2?? August 20, 2014 07:08AM |
Re: ormerod-2?? August 20, 2014 07:57AM |
