New experimental firmware 0.78m-dc42 and web interface 0.99 August 25, 2014 10:32AM |
1. Bug fix: changing the heat sample interval via the M135 command no longer requires the I and D PID parameters to be scaled.
2. Bug fix to the JSON variable name of the extrusion factors array in the web server status response. Needed to support web interface 0.99.
3. When saving the name of a file being printed, ensure that the name of the file is null terminated, to prevent possible buffer overflow later on.
4. Removed redundant function SetStepHypotenuse and associated variables.
1. The active and standby temperatures of each tool are now displayed and can be independently adjusted.
2. Setting the active temperature of a tool no longer selects it. To select a tool, click on the "Head 1" or "Head 2" text.
3. When connecting, the active and standby temperatures, speed factor and extrusion factors displayed are synced to the values currently in use on the printer. If a file is being printed, then the file data and print progress are displayed.
1. Web interface 0.99 requires firmware 0.78m-dc42. Versions 0.95 and later of the web interface should work with 0.78m-dc42. So update the firmware first, and the web interface after you have the new firmware running.
2. As with the RRP 0.78a official release, the X motor connections should be reversed compared with RRP firmware 0.78 and earlier or my firmware 0.78j-dc42 and earlier.
3. If upgrading from 0.65 or 0.57 series firmware, there are other changes you need to make, described in other threads.
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 25, 2014 12:54PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 25, 2014 01:23PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 25, 2014 05:07PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 03:38AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 01:02PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 02:26PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 02:32PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 04:24PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 04:59PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 26, 2014 05:20PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 11:59AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 12:07PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 01:39PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 01:54PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 02:46PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 27, 2014 05:21PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 28, 2014 02:43PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 28, 2014 04:28PM |
muggi
Hi David,
thanks for your help. Another question. Did you changed the PID Max on firmware 078m/n???
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 28, 2014 11:46PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 29, 2014 04:47AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 29, 2014 05:03AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 29, 2014 06:08AM |
dc42
1. Are there any T commands in your print file?
dc42
2. When you start the next print and the temperature drops, which nozzle (if any) does the web interface show is the active one?
dc42
You may find it helpful to use web interface version 1.00, which I released yesterday. It shows the status of each heater more clearly.
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 29, 2014 07:12AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 29, 2014 07:45AM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 30, 2014 03:01PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 30, 2014 03:27PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 30, 2014 07:58PM |
Re: New experimental firmware 0.78m-dc42 and web interface 0.99 August 30, 2014 08:12PM |
jstck
If there are no files in the gcodes directory on the SD card, the web ui will give the following error in the console:
Uncaught TypeError: Cannot read property 'files' of undefined 192.168.0.14/js/reprap.js:853
