Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 06, 2014 04:37PM |
The default S parameter for the PIDs is now 1.0 for all heaters. This is to make transitioning to my firmware easier on Ormerod 1 printers using the original ATX power supply.
Implemented the M570 command to allow the heater timeout to be adjusted. The default is 120 seconds.
Minor correction to the move lookahead code.
M81 command now waits for all moves to complete before turning the power off.
Fixed a problem with a missing variable in a cookie that caused problems for some users
Fixed an issue with graph sizing that caused the interface to no longer work in Chrome on Android
The file information displayed on clicking the info icon next to an SD card filename now includes the object height.
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 03:20AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 03:24AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 03:58AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 05:10AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 05:24AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 06:10AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 10:33AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 12:25PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 01:05PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 01:07PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 01:08PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 02:18PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 02:33PM |
Mercnik
I have problems with Y axis
I home all axes, and it works corectly. The movement is ok, no belt sliping or something
but when i send G32 command.
The bed seems not to be on right coordinates. it is at y180 to 190 on P1 and when it moves to P2 the bed moves even further to almoust the end.
But the bed should be at y175. So the x axis crashes in bed.
It's shoving 160, but x axis is over the edge of bed
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 02:43PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 02:55PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 03:21PM |
Mercnik
I tried it again
And as soon as it moves from P0 to P1.
Y coordinates jump from 0 to -7.5.
And then it drives to y160, but is 7.5 more
From P1 to P2 y also moves slightly, for at least 5mm
At P3 it shows X220 y-7.5
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 03:42PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 04:23PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 07, 2014 04:51PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 03:49AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 05:31AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 07:12AM |
Mercnik
I have checked sys files for M556 code. but didn't find any
send M556 command, and got response -- Axis compensations - XY: -0.01154, YZ: 0.01859, ZX: -0.00385
Where could the command be.
I don't have a setbed file
G31 Z2.20 P553 ; Set the probe height and threshold (deliberately too high to avoid bed crash on setup) M556 S78 X-0.9 Y1.45 Z-0.3 ; Put your axis compensation here
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 08:19AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 08:57AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 09:56AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 11:15AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 11:51AM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 01:04PM |
Re: Minor updates: firmware 0.78r-dc42 and web interface 1.02 September 08, 2014 02:01PM |
