What went wrong?
Posted by Davek0974
What went wrong?
September 14, 2014 02:41PM
Was trying to print the skull.stl that was mentioned on another thread, it's on thingyverse.
It was working perfectly for four hours or so then I heard a crunching noise from downstairs, checked the printer upstairs and find the head jumping about and the print catching on the sensor board and fan outlets, I aborted the print as it was clear it was wrecked.
You can just about see the problem in the pics, the support for I think the eye sockets was sticking way above the perimeter, about three mm higher on both sides, it was not formed correctly.
Bloody annoying as this was the best print yet, the half that was printed was 100% perfect on the outside, not happy sad smiley
Any suggestions?
Another RS Ormerod Mk1 meets the world smiling smiley
Retired now but I used to make....
CNC Machined Mk1 aluminium bed support plates for the Ormerod
CNC machined X-plates and ribs for Mk1 & Mk2 Ormerods
CNC machined bed support arms for the Mk2 Ormerod.
Dual Hot-End heatsink blocks.
open | download - image.jpg (371.2 KB)
open | download - image.jpg (311.6 KB)
Re: What went wrong?
September 14, 2014 03:30PM
How fast was your print?, I have no other advice for up curling than to print slow and let the nozzle heat iron down the buggers, these were my setting for "Skull with Pointed Teeth"
[www.thingiverse.com]
; generated by Slic3r 1.0.0RC3 on 2014-05-15 at 21:21:15
; layer_height = 0.24
; perimeters = 2
; top_solid_layers = 4
; bottom_solid_layers = 3
; fill_density = 0.25
; perimeter_speed = 40
; infill_speed = 40
; travel_speed = 60
; nozzle_diameter = 0.5
; filament_diameter = 1.75
; extrusion_multiplier = 0.90
; perimeters extrusion width = 0.50mm
; infill extrusion width = 0.87mm
; solid infill extrusion width = 0.85mm
; top infill extrusion width = 0.85mm
; first layer extrusion width = 0.38mm
Pictures of Mr. Green and Mr. White in this posting and downstream
[forums.reprap.org]
Erik
September 14, 2014 03:42PM
Thanks, I may be running slightly faster than that, will check.
The quality of the printed bit was fantastic, makes it more annoying.
I will have to wait until next weekend for a reprint as I don't want risk letting it run at night, if the same thing happens it might rip the sensor board off.
September 14, 2014 03:52PM
I also reduce the "small perimeter" speed to 10mm/sec. But I'm not sure whether those eye sockets count as small perimeters.
September 15, 2014 01:53AM
The noise is probably from the motors skipping steps because the movement is blocked by the print.
It looks like your eye is curling upwards. I have seen a similar thing happening several times when the object has a slight slope upwards - like the lower side of balls (your eyeball).
As I have no idea how to solve this problem, I'm very much looking forward to see what comes out of this thread.
Best regards,
Carsten
September 15, 2014 03:49AM
Something to notice, your print: infill only where needed, my print infill 25% everywhere
Could be that the infill everywhere helps in keeping the curling down a bit - or help distributing the heat from the eye sockets
Edit: some ideas in this thread (nophead esp.)
[forums.reprap.org]
Erik
Edited 1 time(s). Last edit at 09/15/2014 03:58AM by ormerod168.
September 15, 2014 04:23AM
I think it is mostly a matter of temperature, speed and cooling. I've had this happen on overhangs where they curl upwards, but with no clear pattern to when it arises (I don't know the common factor among which prints do this and not). My best-guess theory though:
When it prints the outermost perimeter the ones inside are still soft enough that when it cools (and therefore shrinks a little bit) the whole perimeter does so. It happens on overhangs (outward slopes) because the outer perimeter has very little material underneath to stick to, which otherwise tends to keep it in place, and also less material to lead the heat away.
Since most slicers do all perimeters at once (usually from the inside and out), the other perimeter layers are just newly laid down. Layer time is not the biggest factor, but "perimeter laptime" is. Most slicers have options to slow down to do a certain minimum layer time, but in the case of this model it can spend a lot of time on the cranium part, but the eyes are still pretty fast.
A slicer option to do things in a different order, such as inner perimeters -> infill -> outer perimeters might help a little bit, in that the inner perimeters will have had some more time to cool down before the outer is laid, but since the next layer inner perimeter is then done right after it might not mean that much. Also not all models will have any significant amount of infill. Apart from just having a steady flow of cooling air, one thing to try could be to reduce perimeter speed even more. Not just external perimeters, but all of them.
September 15, 2014 09:17AM
Curl-ups can be a real challenge. I've sat babysitting prints with a flat needle file, waiting for the head to get out of the way and then pushing and grinding down the up-curls after every layer at the critical parts of the print. The only thing is that the print needs to be big enough for the head to get out of the way for long enough - or you have to put a sacrificial throwaway structure next to the part to force the head away from the main print every layer.
Apart from the thermal effects, another reason for the up-curls is if the perimeter starts and stops at the corner of an overhang. In that case the corner blobbing exacerbates the up-curl by adding material just where you don't want it. You can easily see that the up-curl on a corner where the perimeter starts & stops is worse than corners that are not used as start places even if they have similar overhangs. You could try setting "Seam position" in Slic3r (I have it under "layers & perimeters" in version 1.1.6) to "Random" which will hopefully result in the perimeter not being started at the same corner for every layer (If I recall correctly previous versions of Slic3r had "Randomise start position" as a check box instead and it did not work all that well because the start points were still not all that random, don't know about the later versions). For parts that you design yourself, try to make all corners rounded - I appreciate that you cannot do so for the part in question.
For interest, I have recently bought the slicing program "Simplify 3D" and curl-up is one thing that is improved, I think due to a "coast to end" feature that stops extruding just before reaching the end of a perimeter and so reduces blobbing at corners. It's probably not however so dramatic an improvement as to warrant the hefty price tag for that feature alone (though overall I am not disappointed with its value as it has several other good features as well).
[edit] I also notice that you have a great deal of stringing on your print. This could be a sign that your hotend is too hot - or possibly that you have not set your retraction large enough (I use 4mm).
Dave
Edited 1 time(s). Last edit at 09/15/2014 09:20AM by dmould.
September 15, 2014 01:51PM
On the rare occasions that I see curl-up, I have used the slider control in the web interface to slow down printing. The hot nozzle won't snag on the print if it is moving slowly enough.
September 15, 2014 02:29PM
Wow, so many things to try.
I'm going to try and re slice it but only from 5mm below where the trouble started to the top, that should save a lot of time in testing.
I'll also turn on full infill at 25% and slow down a bit
Try that lot first.
I did try pulling the curl-ups off while it was paused but it didn't work and the next layer would not sit right so I aborted the print.
Could it be lack of cooling?
I fitted a quiet fan but it does not put as much through the cooling vents at the bottom of the duct due to lower pressure.
I could rig another fan maybe?
Edited 1 time(s). Last edit at 09/15/2014 02:32PM by Davek0974.
September 15, 2014 02:36PM
dc42
On the rare occasions that I see curl-up..
I don't find it rare, for Me it's a general problem
dc42
No, but it will still leave a mess (for Me it will)
Do You feel lucky? ; -)
Massive Overhang Test:
September 15, 2014 06:42PM
Hi, when I modified Big Blue 360 to allow clearance for DCs I.R. Probe board, there was a corner with a Mass of Hot Plastic that did the same thing.
I didn't want to reduce the speed just because of this one small area (there is one of the Fan mounting brackets in the same spot that compounded the problem),
so I placed a pillar up from below it to anchor the corner down. It worked a treat. So I'd suggest infilling the whole area to hold the devil down.
Good Luck,
Kim..
September 15, 2014 07:22PM
I'm with Erik on this one - I've found that "infill only when needed" makes curling worse, and have successfully printed this skull at 10% infill...I don't tend to go lower than that these days. I've also fitted 2 x secondary fans as per @Appjaws1 design in another thread and that has really helped reduce curling almost to the point of "no issue" from my previous position of "major pain" - hope this helps...persist with the print though...it is a real head turner smiling smiley
September 16, 2014 02:06PM
I've set the parameters listed above m split the design in slic3r and have the top half running again now. I split about 5mm below where the trouble started before and so far it looks perfect.
Only problem if it works is, I don't know which change fixed it winking smiley
My guess is the solid infill at 25% as the speed reductions were very small.
The other bits I know nothing about are the extrusion width settings, mine were all on slic3r defaults of "auto", can anyone explain what they do?
September 17, 2014 01:04PM
Looks good, in fact I quite like the "half-skull" effect smiling smiley
I've put my speeds back as there really was not much difference, I have also ticked the randomise seams option and scaled it up to 105% winking smiley
G-codes all ready and will give it a go Saturday as I'm in all day and can monitor it.
The half skull took five hours to run.
open | download - image.jpg (443.9 KB)
September 18, 2014 11:24AM
Talk about akaziuna'a Skull with Pointed Teeth, here's a new skull design on thingiverse, it looks like a mod of same but no credit payed so it can't be ahem...
kellyd
This is my finished product of my 3D Design. It is a eye-catching skull that successfully holds a candle and holds coins within the hollow skull. I am extremely pleased with the final result.
Erik
September 20, 2014 06:10AM
Davek0974
Will light a candle for you - good luck! :-)
Erik
September 20, 2014 06:53AM
About three hours into an estimated eleven hour print and it's looking good so far smiling smiley
September 20, 2014 04:32PM
Alas, poor yorik.....
smiling smiley
open | download - image.jpg (527.9 KB)
September 20, 2014 04:39PM
And his half-brother, Boris...
winking smiley
open | download - image.jpg (319.4 KB)
September 23, 2014 01:57AM
Davek0974
smiling smiley
Great looking skull! - so you did print it in one go, congrats!
What do you think made the difference, infill, speed, cooling or...?
Erik
September 23, 2014 04:01PM
Yes, one, ten hour print!
I think it was the infill, needs a full mesh not only where it thinks it does.
Used half a reel of filament too!
