Z-Axis Sensor strange beahviour September 23, 2014 03:28AM |
Re: Z-Axis Sensor strange beahviour September 23, 2014 05:10AM |
Re: Z-Axis Sensor strange beahviour September 24, 2014 09:19AM |
Re: Z-Axis Sensor strange beahviour September 24, 2014 10:46AM |
Re: Z-Axis Sensor strange beahviour September 25, 2014 01:31AM |
I got the master tree. will test with dev tree later today.Quote
dc42
1. Which version of my firmware fork are you running? The version I recommend is 0.78r-dc42 available via [github.com].
I got your Webinterface also for master tree. I just copied the contents of SD-image as I did with original Ormerod firmware from RepRapProQuote
dc42
2. You need to be using my version of the web interface, available at [github.com]. I think you may be using RRP's version, which would account for the axes not being shown as homed.
I have indeed Ormerod 1 with the square MDF Y-Plate and the ribbon Heatbed cable. External ATX power etc.Quote
dc42
3. Can you confirm that you have an Ormerod 1, not an Ormerod 2? The homing files will need changing for Ormerod 2.
Re: Z-Axis Sensor strange beahviour September 25, 2014 05:38AM |
Re: Z-Axis Sensor strange beahviour September 25, 2014 05:33PM |
Re: Z-Axis Sensor strange beahviour September 25, 2014 05:52PM |
Re: Z-Axis Sensor strange beahviour September 25, 2014 06:18PM |
Re: Z-Axis Sensor strange beahviour September 26, 2014 02:21AM |
Re: Z-Axis Sensor strange beahviour September 26, 2014 04:40AM |
Re: Z-Axis Sensor strange beahviour September 26, 2014 04:52AM |
Re: Z-Axis Sensor strange beahviour September 26, 2014 07:16PM |
DasBasti
another thing is that when is home x and y axis and move to a specific point. i.e. the z homing point G1 X65 Y8.
I do a z homing afterwards and move to the same point (G1 X65 Y8) the head actually moves a couple of millimeters in x and y direction. what is happening during z homing?
