Re: New firmware 0.96a and web interface 1.05 October 22, 2014 10:16AM |
Re: New firmware 0.96a and web interface 1.05 October 22, 2014 10:46AM |
jstck
In theory it should be possible to give a very accurate estimate of the print time, if you have the gcode, any in-printer settings (such as firmware limits on speed and acceleration), and estimates of any "wait for warm-up" commands (which generally only happen once at the very start). If you go through each move and calculate how long it will take and sum that up, how far does that really differ from actual print time, and if it does, what is causing it? Such a calculation might be possible to churn through in printer firmware, but I'm not sure how useful that possible extra precision is really worth to me. In all honesty, not very. The current estimates (with their flaws) have always been sufficient for my needs at least.
Re: New firmware 0.96a and web interface 1.05 October 22, 2014 11:19AM |
Re: New firmware 0.96a and web interface 1.05 October 22, 2014 04:47PM |
appjaws1
My print that simplify3d reported as build time 90.99 mins (1.52hr) - 1hr 30mins actually took 2hr 7mins. so that program is not very accurate.
Re: New firmware 0.96a and web interface 1.05 October 23, 2014 02:34AM |
dmould
It also means doing a "dry run" by reading the entire g-code file before starting the print, which could potentially take several minutes (though such "priming" could be done under user control).
Re: New firmware 0.96a and web interface 1.05 October 23, 2014 10:42AM |
jstck
dmould
The Duet CPU is pretty snappy, I would guess it could churn through a typical 2MB/100k-line file in just a few seconds (and possibly be limited by the SD card speed.
Re: New firmware 0.96a and web interface 1.05 October 23, 2014 03:07PM |
Re: New firmware 0.96a and web interface 1.05 October 23, 2014 07:32PM |
Re: New firmware 0.96a and web interface 1.05 October 24, 2014 10:03AM |
