Help with 0.78t-alpha-dc42 October 20, 2014 03:22PM |
Re: Help with 0.78t-alpha-dc42 October 20, 2014 05:19PM |
PaulHam
The problem is that I have only just upgraded to this new 0.78t-alpha-dc42 version, previously i was on RepRapFirmware-57h-dc42. I havent added another hot end, i just have the dual sense board with one hot end.
Im trying to print the modified part but the head1 doesnt work, the extruder doesnt spin and it doesnt heat up like it used to. I have to click the words 'Head1' and it turns it on.
PaulHam
Do i need to change my gcode start on cura for it to select the correct tool?
PaulHam
I noticed that after printing, and after reseting a print the axis all turn yellow, the same way they do when the axis are not homed.
PaulHam
Im also having issues with the Z homing (in addition to it not sensing height without paper on top of the glass), when it coems down to home, it stops but doesnt set the Z to 0 or 0.24 (whatever it is supposed to) it stops at the height i set in config.g (G31 Z1.10 P500)
Re: Help with 0.78t-alpha-dc42 October 20, 2014 05:44PM |
Hi, I've just got into the loop so I'm still learning.Quote
PaulHam
Ive been out of the loop of a little while and now it feels that im too far out of it to work out what im doing.
I will also be attempting a custom firmware update, and also a better height / Z sensor once I get used to the standard firmware.Quote
PaulHam
I can't recall being able to click on 'head 1', but I am still running original firmware. Which software are you clicking in? A modified web interface or pronterface?Quote
PaulHam
How did you upload it? I am only used to copying it to the SD card and haven't had any problems. I understand the cutom firmware allows you to FTP or upload through the web browser. It might help if you give more details than you think we should know.Quote
PaulHam
somehow i managed to get it printing and i played with the speed setting, but i got approximately 25% through and it said it had finished (web interface says its printed fully, perhaps a problem when i uploaded it)
Now I'm lost. cura, selecting tools, axis turning yellow?Quote
PaulHam
As I understand it, that G code tells the printer that the Z sensor has a reading of 500 when it is 1.1mm above the bed. What height does it stop at? If it stops at 1.1mm when the Z sensor reads 500 then I would guess you have a setting somewhere which is telling the printer to not do the usual 'move down 1.1mm after seeing 500 on the sensor'Quote
PaulHam
Sorry, don't understandQuote
PaulHam
I have a feeling the home files are incorrect aswell
I thought I could help but I'm still in the shallow end, learning before I get to the deep end. My advice, as you said you were out of the loopQuote
PaulHam
Can anyone decode the above and offer some assistance?
Re: Help with 0.78t-alpha-dc42 October 20, 2014 05:56PM |
