(Ormerod 2) M556 causes repeated z homes to track over bed October 22, 2014 11:00AM |
M556 S78 X0 Y0 Z0
FIRMWARE_NAME:RepRapFirmware FIRMWARE_VERSION:0.78c ELECTRONICSuet + Extension DATE:2014-09-18
G91 G1 Z5 F200 G90 G1 X55 Y0 ; Adjusted to suit machine. G30 G1 Z3 F200 ; Move to 3mm after home.
M111 S0 ; Debug off M550 POrmerod 2 ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address M552 P192.168.85.66 ; IP address M553 P255.255.255.0 ; Netmask M554 P192.168.85.1 ; Gateway M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M305 P1 R1000 ; Set the hot-end thermistor series resistor to 1K M569 P0 S0 ; Reverse the X motor M92 E416 ; Set extruder steps per mm M558 P2 ; Use a modulated Z probe G31 Z4.3 P540 ; Set the probe height and threshold. M557 P0 X55 Y00 ; Four... M557 P1 X55 Y183 ; ...probe points... M557 P2 X220 Y183 ; ...for bed... M557 P3 X220 Y00 ; ...levelling M556 S74.25 X0.25 Y0.65 Z0.625 ; Put your axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M563 P1 D0 H1 ; Define tool 1 G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures
G91 G1 Z5 F200 ; z-axis definitely not on limit. G90 M558 P1 G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-30 S1 G92 X0 M558 P2 G91 G1 Z-5 F200 ; Return z-axis. G90 G1 X10 ; Move x-axis 10mm G92 X0 ; Re zero x-axis.
G91 G1 Z5 F200 ; z-axis definitely not on limit. G1 X20 F2000 ; x-axis definitely not on limit. G90 G92 Y0 G1 Y-250 F2000 S1 G92 Y0 G1 Y3 F200 G1 Y-30 F200 S1 G92 Y0 G91 G1 X-20 F2000 ; Return x-axis. G1 Z-5 F200 ; Return z-axis. G90 G1 Y5 ; Move y-axis 5mm G92 Y0 ; Re zero y-axis.
G1 Z10 F200 G1 X55 Y00 F2000 ; Adjusted to suit machine. G30 P0 Z-100000 G1 Z10 F200 G1 X55 Y183 F2000 ; Adjusted to suit machine. G30 P1 Z-100000 G1 Z10 F200 G1 X220 Y183 F2000 ; Adjusted to suit machine. G30 P2 Z-100000 G1 Z10 F200 G1 X220 Y00 F2000 ; Adjusted to suit machine. G30 P3 S Z-100000 G1 Z10 F200
Re: (Ormerod 2) M556 causes repeated z homes to track over bed October 22, 2014 11:28AM |
Re: (Ormerod 2) M556 causes repeated z homes to track over bed October 22, 2014 02:51PM |
Re: (Ormerod 2) M556 causes repeated z homes to track over bed October 22, 2014 04:39PM |
Re: (Ormerod 2) M556 causes repeated z homes to track over bed October 23, 2014 11:41AM |
Re: (Ormerod 2) M556 causes repeated z homes to track over bed October 23, 2014 02:45PM |
