UPS for Ormerod 2 November 07, 2014 01:05AM |
Re: UPS for Ormerod 2 November 07, 2014 02:03AM |
Re: UPS for Ormerod 2 November 07, 2014 02:24AM |
Re: UPS for Ormerod 2 November 07, 2014 03:04AM |
Re: UPS for Ormerod 2 November 07, 2014 07:22AM |
ormerod168
...A 600VA UPS should do just fine and give you lots of time to do a controlled shutdown..
Re: UPS for Ormerod 2 November 07, 2014 09:27AM |
Re: UPS for Ormerod 2 November 07, 2014 11:03AM |
Yes, agree Dave, this is my ideal solution for here in Cornwall in the UK where we get quite a few outages over the winter, many for a few seconds to minutes, presumably as everything resets after a short in the high winds?Quote
dmould
Instead of going to the expense of a UPS, you could buy a 12V lead-acid utility battery and a battery charger suitable for leaving on constant float charge, then do away with the mains PSU altogether and run the Ormerod directly from the 12V lead-acid battery. In most places in the UK there is more risk of the invertor part of a small UPS failing than the grid mains failing, so using a UPS actually *increases* the risk of a power outage.
Dave
Re: UPS for Ormerod 2 November 07, 2014 02:55PM |
