Dead heated bed November 07, 2014 06:36PM |
Re: Dead heated bed November 08, 2014 03:06AM |
Re: Dead heated bed November 08, 2014 12:47PM |
Re: Dead heated bed November 08, 2014 01:23PM |
Re: Dead heated bed November 08, 2014 04:09PM |
dc42
I'm a little surprised by that method of construction. Usually when a crimp tag like that one is used, the tag would be clamped in direct contact with whatever the wire has to be connected to. But in this case, it looks to me that the current has to flow from the tag through what looks like a steel spring washer, to the nut, then to the screw thread, down the screw, and finally from the screw head to the copper trace it is soldered into. The nut is brass, but the screw looks as though it may be steel. So there is quite a lot of opportunity for bad contact, leading to overheating.
Re: Dead heated bed November 08, 2014 04:23PM |
Re: Dead heated bed November 08, 2014 05:45PM |
Re: Dead heated bed November 08, 2014 07:13PM |
Re: Dead heated bed November 08, 2014 09:23PM |
Re: Dead heated bed November 09, 2014 04:41AM |
dc42
...I would fit the spring washer under the tag instead of between the tag and the nut, so that the tag is in direct contact with the brass nut...
dc42
...Please note that I have no experience with the O2 variant of the heated bed, so the above is based only on what I can see in your photos
Re: Dead heated bed November 09, 2014 04:52AM |
Pyro
Just to double check, you are suggesting that I apply solder to the screw after a new one is fitted?
ormerod168
but can the PCB carry the pressure from the small surface of the spring washer or will it give over time?
Re: Dead heated bed November 09, 2014 05:24AM |
Re: Dead heated bed November 09, 2014 07:18PM |
Re: Dead heated bed November 10, 2014 04:45AM |
Re: Dead heated bed November 10, 2014 05:17AM |
Re: Dead heated bed November 10, 2014 05:34AM |
Re: Dead heated bed November 10, 2014 07:00AM |
Re: Dead heated bed November 10, 2014 07:35AM |
Re: Dead heated bed November 10, 2014 08:18AM |
Re: Dead heated bed November 10, 2014 09:08AM |
Re: Dead heated bed November 10, 2014 09:58AM |
Re: Dead heated bed November 10, 2014 04:53PM |
Re: Dead heated bed November 11, 2014 05:03AM |
Re: Dead heated bed November 11, 2014 05:56AM |
Re: Dead heated bed December 12, 2014 09:43AM |
Re: Dead heated bed December 12, 2014 09:50AM |
Re: Dead heated bed December 12, 2014 10:39AM |
Re: Dead heated bed December 12, 2014 02:57PM |
Re: Dead heated bed December 19, 2014 05:16AM |
