Re: PanelDue (touch-screen controller for Ormerod) availability January 21, 2015 11:29AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 03:26AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 07:08AM |
dc42
1. I have confirmation from a customer that this display [www.ebay.co.uk] also works with the PanelDue...
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 08:24AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 11:54AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 12:50PM |
reprapprochina
Hi, David:
RRP UK just announced the news of the availability of multi-extruder upgrade kits for all Ormerod kits, as well as the recently launched Huxley Duo, the same question about PanelDue is whether or not compatible with new upgraded OM2.
Thanks,
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 12:58PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 01:34PM |
Fpex
I am honestly not so interested in RRP heads and I have already decided for the duet4x .... But that mixing chamber they show is so sweet and I do hope the diet4x is compatible with their board.
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 03:06PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 03:28PM |
Fpex
My understanding is the the noise issue is onky at low temperatures that does not affect functionality. When this is not true, than I better cancel the duet4x order.
For my Kossel I decided for a smoothieboard with external motors. But I am not sure I will ever manage to put a kraken on a Kossel effector.
Re: PanelDue (touch-screen controller for Ormerod) availability January 23, 2015 03:32PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 24, 2015 04:27AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 24, 2015 08:35AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 24, 2015 12:25PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 26, 2015 12:11PM |
dc42
I've done some work on the enclosure design produced by dmould and appjaws1. The mounts for the controller PCB are still in the wrong place, so are the holes for the Erase and Reset buttons and the USB connector, however the cutouts and mounting stands should now be correct for the non-Itead 4.3 inch display. As I may not be able to work on it again until late tomorrow, I have checked it into [github.com] in case anyone who already has a PanelDue wants to do anything with it.
Re: PanelDue (touch-screen controller for Ormerod) availability January 26, 2015 03:37PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 26, 2015 06:21PM |
muggi
i have a itead 4.3 and can´t find a working config in the scad file.....
Re: PanelDue (touch-screen controller for Ormerod) availability January 27, 2015 05:22AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 27, 2015 07:31AM |
pantau
I tried to convert the attached PanelDue housing .scad files to .stl using OpenSCAD. When doing it I get the error "Object isn't a valid 2-manifold! Modify your design." Is there a setting or another program I need to use to do the conversion?
Re: PanelDue (touch-screen controller for Ormerod) availability January 27, 2015 04:43PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 27, 2015 05:14PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 27, 2015 05:22PM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 06:05AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 06:22AM |
bobexuk
Hi
my itead Lcd s have arrived and they are 3.3volt not 5 volt
luckily I had not changed the jumper from trying another lcd I had
just be careful about the voltage selection
regards
Bob
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 06:56AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 07:08AM |
Hi Dcrocker,
1. All lcd module need 5V on the VCC pin.
2. ...
ITEAD Studio
On Mon, 17 Nov at 10:08 pm , Dcrocker wrote:
Thanks for your quick response and the schematic of the 3.2WD. I have some further questions
1. Supply voltage
Please confirm what voltage the ITDB02-4.3 and ITDB02-5.0 displays need. The Wiki pages for both of these say "Power supply 3.3V" near the top, however the pin diagram near the bottom says "5V power supply pin". The schematic for the 5.0 shows a voltage regulator, so I think it needs 5V on the Vcc pin. Can you confirm that both of these displays need 5V power, like the ITDB02-4.3?
2. ...
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 08:15AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 10:07AM |
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 10:12AM |
dc42
I think you should change the jumper to 5V, or else short those 2 pads. There is a danger that the display is receiving some parasitic power through the I/O pins, which would not be good for the ATSAM3S chip on the controller and even less good the SSD1963 on the display.
I don't have any immediate plans for the rotary encoder, and the PanelDue user interface is designed for touch. I do have a good rotary encoder driver that I wrote for another project, so I may add some minimal rotary encoder support and leave it to others to add more to the firmware if they wish.
Re: PanelDue (touch-screen controller for Ormerod) availability January 28, 2015 10:45AM |
