PanelDue Discussion & Troubleshooting
Posted by x4FF3
January 24, 2015 02:01PM
hi,
today i had time to make a wire for the paneldue. display(800x480) works! but the touch panel is 180 degrees inverted to the display. how can i flip the orientation?
kind regards
david
Re: PanelDue Discussion & Troubleshooting
January 24, 2015 02:47PM
Go to the Setup pane and run the Calibrate Touch procedure. If you have an Info pane instead of a Setup pane, upgrade the firmware.
