New experimental firmware 0.96k and Duet Web Control 1.01 January 30, 2015 10:47AM |
* Introduction of new JSON status responses, see here
* Dropped support for old (rather ancient?) web interface (don't worry, iamburny's web interface is still working if the default "reprap" password is used)
* Implemented (optional) password protection in the HTTP server, meaning each network protocol can now be password-protected in my fork
* Added new functionality to the HTTP server (rr_mkdir, rr_reply and preparations for rr_config)
* Implemented firmware-based print time estimations
* Before a file being printed is closed, DoFilePrint waits for all moves to finish first. This makes it easier for the web interface/PanelDue to determine when a file print has actually ended
* M98 allows absolute paths, so files from directories other than /sys can be run
* Improved debug/diagnostics code (see Platform::ClassReport and M122 in particular) and added new diagnostics test
* Moved LWIP's stats_display call from Platform to Network class
* Merged in all of dc42's changes up to 0.78za and several changes from his following releases (thanks again, dc42!)
* (Hopefully) added full support for dc42's PanelDue controller and changed the default AUX baud rate to 57600 (you may have to upgrade your PanelDue firmware to get it working though)
* Bug fix: rr_fileinfo returned an error when a directory path was passed
* Bug fix: Pause macro isn't executed when M25 is called twice
* Bug fix: Finally fixed occasional "Lost data connection" upload bug in the FTP server
* Bug fix: File list response returned invalid JSON responses for empty directories
* Bug fix: "ok" replies for Telnet clients are followed by CRNL again
* Bug fix: Fixed issue where the FTP server didn't handle AUTH properly and broke support for the latest FileZilla release
* Bug fix: filenameBeingUploaded in the Webserver class was not actually set when an upload was initiated, so failed uploads weren't deleted automatically
* Responsive design for all Bootstrap screen sizes (phone, tablet, desktop)
* Support for dynamic numbers of heads, tools and extruder drives
* Execution of custom macro files from /macros directory (you can upload G-Code files to it via FTP)
* Vastly improved Print Status page; the print time by layer chart is now fully interactive and can be panned or zoomed if there is a reasonable amount of samples
* Improved reconnect behaviour in cases a file is being printed
* G-Code files can be managed in sub-directories of /gcodes
* Beep and Message support (see M300 and M117) for printer setups without PanelDue
* New favicon(s)
Re: New experimental firmware 0.96k and Duet Web Control 1.01 February 06, 2015 07:11AM |
Re: New experimental firmware 0.96k and Duet Web Control 1.01 February 08, 2015 07:09AM |
appjaws1
This experimental release is great, I have been running this firmware and operating the new web control for a few weeks now and I am very pleased with it. The firmware is working without problems and the web control is very nice and well laid out and the upcoming enhancements to the web control facilities will bring great benefit, being able to select fields to display on screen and in the introduction and control of macros and filament spool records.
It has been great to operate my ormerod from my phone.
try it, see what you think, zombiepantslol, I'm sure, will be pleased for any suggestions to improve the software.
Re: New experimental firmware 0.96k and Duet Web Control 1.01 February 08, 2015 10:10AM |
var amount = $("#panel_extrude input[name=feed]:checked").val();
Re: New experimental firmware 0.96k and Duet Web Control 1.01 February 08, 2015 11:30AM |
