Ormerod Bigfoot mod!
February 04, 2015 04:13AM
Scaaary...
A perfect fit
y-z extrusions arrested with t-nuts
Yes you can keep those cables Octo..
Ta-daa..
the beauty and the beast
Erik
Re: Ormerod Bigfoot mod!
February 04, 2015 04:28AM
Impressive!
Do you see a difference in the bed levelness?
February 04, 2015 01:22PM
Erik seems to have a thing for 8 legged creatures!
Looks really good. Is the wood on the x-axis functional?
February 04, 2015 03:43PM
tstone
No, at least not with both printers standing on level ground, the printer resting on four points is actually a bad idea, the y-extrusion will twist to some small degree if not level - but in practice the effect is very small and doesn't matter
The electric saw undercarriage part I used for bigfoot is cast aluminium and very strong so will not twist, ad to that the bolted on y-extrusion
Still have the effect of force from the bowden cable though, will try dc42's idea with 2 extra cables to even that out
Erik
February 04, 2015 03:52PM
jamesf
Yes LOL! (or more like yrkkk) - its the stangest thing, its not down to the number of legs that's for sure, but I'm working on it! - may take another 60 years but I will get there :-)
It's a cable elevator to prevent the cables strangling the chimney plug of johneato's Control air to the nozzles mod - I wish he would make a steam version with whistle on top as I usually forget to pull the plug (ABS print) and have to chase the hotend around, desperately trying remove the dam thing without loosing any steps :-)
Erik
February 11, 2015 10:28AM
Did you build that butterfly on yours?! incredible stuff
February 26, 2015 12:55AM
wa...so beautiful.
February 28, 2015 01:35PM
88Zombies
Yes, easy to print and makes for a nice gift
Butterfly 3D Printable:
[www.thingiverse.com]
Erik
February 06, 2016 09:56PM
I love this! I've had my eye on it for a while. Since nobody has asked yet - what is the thing that you're using as a base? Are the aluminium brackets that you're using for the Y-axis ends part of that base, or did you cut them yourself? Where did you get the T-bracket that you've used to join the Y and Z axis?
My 'rod is currently sagging badly towards the X-axis, and I'm looking out for ways to perk it up and improve the rigidity of the Z-axis to make it more square. It looks like you've managed to get a bolt completely through the Y extrusion and into a t-slot nut that's fitted into the Z... is that correct? If so, that's genius! Is it more sturdy?
Edited 1 time(s). Last edit at 02/06/2016 10:00PM by 0x0000.
February 07, 2016 02:35PM
0x0000
I love this! I've had my eye on it for a while. Since nobody has asked yet - what is the thing that you're using as a base?..
Thank you for your kind words! - the base is from an electric saw I found at the scrap yard, made of cast aluminium, top is milled so perfectly flat and very very stable - perfect for the job
Not exactly this one but something like it:
..will answer the rest tomorrow..
Erik
February 10, 2016 01:12PM
Nice!
smiling smiley
July 04, 2017 11:51AM
I Love the mods you did.
I can't wait to get mine in the same sturdy shape.
Edited 1 time(s). Last edit at 07/04/2017 11:56AM by Karoo Klong.
July 05, 2017 03:47PM
Karoo Klong
Thank You - I did invest a lot of time and work but it was time well spend and well worth it, the ormerod is a great printer!
BTW, the original cooling design could be better so you may want to print and install something else later, I have this great design from thingiverse installed at the moment, not an easy task to squeeze in but can be done
Erik
July 12, 2017 04:49PM
Ooh! That looks very nice!
Now if I could only actually pro t something.
July 24, 2017 01:37PM
Hi Erik,
that looks a great mod of the Cobra cooler to make it fit Ormerod. Do you have the files you could share? What else is needed to make it fit?
many thanks
July 25, 2017 04:33AM
gwild
Hi Erik,
many thanks
Hi gwild
I would gladly make a mod of the Cobra to fit the Ormerod directly, but my printer is not quite stock anymore and its requires a change to the original hotend to fit it in, I wrote at bit about it here:
[forums.reprap.org]
Basically you will need to make more room underneath the hotend fan and heatsink, also I have changed the heater block to center the nozzle and had to swing it a bit around z to give room for dc42's probe, should not be necessary if not used
To raise the hotend I screwed the heatsink directly to an extra one and mounted this on top of the original heater block, the hotend cooler fan is hold by 2 screws in the upper part of the heatsink
Of the 3 models from thingiverse i chose TAHfan19, it's very well designed with a good evenly split air flow, ad to that a good blower and you have more print cooling air than you will ever need, prints well in ABS (with support), did not modify it in any way, so it's more of a metal fiddle mod :-)
..and I nicked the blower from a defect Makita drill battery charger
Erik
August 12, 2017 12:39PM
att: xiaoyao9184
See no way to attach to PM's so here your request for blueprint over the z-y connector plate, was going to clean out the house over the weekend, but transforming my back-on-envelope to openscad was way more interesting :-)
Attached, DFX and OpenScad file
I used the free holes in both end to line up and pre-mount the plate to the y-extrusion, besides that they are not really needed
from the front
I moved the duet enclosure max to end to make room for a fan deflector, may interfere with the plate if not
2mm aluminium should be fine (or 1mm stainless steel)
As noted, you will have to extend the distance between the holes in the z-food by the amount of material thickness
BTW, another and better mod would be to design a 3D plate (a bit higher at y and wider at z) with both extrusions embedded, that would auto square up the z and y and make assembly much easier..like Lego :-)
Erik
open | download - ormerod zy_connector_plate.dxf (44.8 KB)
open | download - ormerod zy_connector_plate.scad (1.5 KB)
August 21, 2017 09:32AM
Thank you for your time, this can solve the Z-axis problem caused by aging of PLA, without a tripod. smiling smiley
December 02, 2018 07:17AM
Wanted to make the x-runner in aluminium but have no tool to drill the 21mm hole for the bearing, could have bought one but the cost of it would remove the joy of making...luckily I found a piece of scrap extrusion 50x20mm with a square hole of 21x22mm where the bearing would slip right in
Milled of both lower "overhangs" and used one of the uppers for the x-runner bearing....
... the other side was a bit too short to reach the hotend so added a aluminium angle, the bearing was secured with a pair of 4mm set screws
Milled down to 1mm the x-runner bearing side to clear the Z-extrusion - its a close shave!
Added aluminium clamp to secure the belt, drilled 2 holes in the x-rib to access the screws after mounting the belt and the front bearing, to keep the mounting point of the belt on the x-runner in line, to avoid any lift or pushdown of the hotend
..now did I remember to remove the tool before before homing?
Erik
December 03, 2018 06:12AM
Looks very nice indeed!!
This kind of modifications gets me overly excited! grinning smiley
