Cura Plugin Tweak At issue
Posted by Sardi
February 06, 2015 04:39PM
Hi guys.
So no matter what, the g-code from plugin Tweak at Z 3.2 in Cura does not get imported into my g-code file on export.
The plugin file is in folder Cura 14.03 -> plugins, I activate it, set it to change the hot end and bed temps on layer 1 (as that is the layer 2 since the numbering starts with layer 0) but the values for the new temps are nowhere to be found.
Anyone had this problem?
Regards,
Antonio
Re: Cura Plugin Tweak At issue
February 09, 2015 02:27PM
Hi Antonio,
If you go to C:\Users\\.cura\
there is a file called output_log.txt, which is a log file. It might show you an error in the script execution of the plugin.
