Heat Bed Thermistor
Posted by dj_woff
Heat Bed Thermistor
February 21, 2015 12:55PM
Hello All
Following on from my previous post....
Does anybody know the part number or specifications for the heat bed thermistor. The one on my Ormrod decided that is was going to turn itself into charcoal and needs replacing but I can't find any information about it or a replacement on RRPs website.
Many thanks
Russell
Edited 1 time(s). Last edit at 02/21/2015 12:56PM by dj_woff.
Re: Heat Bed Thermistor
February 21, 2015 01:46PM
oops, sorry sad smiley
Pete.
Edited 1 time(s). Last edit at 02/21/2015 01:51PM by Peterdl.
February 21, 2015 04:32PM
If your bed thermistor really has turned itself into charcoal, then you must have accidentally wired it to 12V instead of to the correct connections on the Duet.
AFAIR the thermistor part number is documented in the firmware source, file Platform.h, but as I am away from my PC I can't look it up right now. You can find that file in the RepRapFirmware github repository.
February 22, 2015 04:26AM
From the Platform.h file
Bed thermistor: [uk.farnell.com]
HTH
Doug
February 22, 2015 08:09AM
Thanks All
In response to what's happened there appears to have been a fault with my Duet board as It didn't have control over the heat bed element and when I disconnected it to prevent damage and investigate further i lost the thermistor, Arm core and PSU.
We never did find the exact fault but RRP kindly replaced the duet and PSU under warranty but I didn't push for the thermistor as it was so trivial.
Regards, and thanks again
Russell
