New PanelDue firmware 1.05 and RepRapFirmware 1.00m February 27, 2015 05:27PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m February 28, 2015 03:03PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m February 28, 2015 04:07PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 08:46AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 09:51AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 11:33AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 11:47AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 02:28PM |
pantau
The "._" files are files from a MAC computer, they show up every time you hook up a non hfs filesystem to a MAC. I assume with the latest changes to support macro files with any name they are now visible.
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 04:45PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 04:57PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 01, 2015 05:22PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 05, 2015 02:53PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 05, 2015 04:14PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 05, 2015 07:45PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 06, 2015 04:36AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 06, 2015 01:53PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 06, 2015 02:37PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 09, 2015 10:10AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 09:06AM |
stuart576
The issue doesn't appear to manifest when using my 0.3mm nozzle, and this is the first time I have used my 0.5mm nozzle since upgrading to your new firmware.
Could it be that my extruder calibration is out by a small enough amount not to be noticeable with a 0.3mm nozzle but becomes apparent with a larger nozzle?
Slic3r should work out the extrusion rate based on nozzle size right?
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 09:34AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 11:07AM |
lehar
Hi
When I am printing, the log shows a lot of erros:
"Error: Triangle interpolation: point outside all triangles!"
Why.
I use Slic3r version 1.2.6.
Best regards
Per
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 11:08AM |
lehar
Hi
Why.
Best regards
Per
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 01:40PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 02:27PM |
lehar
Hi
I don't understand how it can be the STL file, because it is sliced to a gcode file!
I use DC software version 1.00m, and new WebInterface 1.02.from zpl.
I don't remember having seen this error before.
The error also comes after it has finished printing. It comes 4-5 times / second.
The printer is waiting to I turn off
/Per
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 10, 2015 03:23PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 11, 2015 01:38PM |
dmould
lehar
Hi
/Per
Sorry, I thought it was a Slic3r error. What log file are you referring to in which these errors appear? AFAIK the only triangle references would relate to the STL, but maybe the firmware also makes use of triangles in some way. Does the print come out OK?
Dave
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 11, 2015 01:54PM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 13, 2015 04:17AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 13, 2015 08:43AM |
Re: New PanelDue firmware 1.05 and RepRapFirmware 1.00m March 15, 2015 09:34AM |
