Re: Bowden tube coming out of extruder May 12, 2015 03:08PM |
Re: Bowden tube coming out of extruder May 13, 2015 05:04PM |
iamburny
Here is a version of MasonStoneHenges Spring loaded extruder arm, modified to take a pneumatic bowden connector
masonstonehenge original
[www.thingiverse.com]
My Modded version
[attachment 54501 DSC_0001s.jpg]
atleast for me
Re: Bowden tube coming out of extruder May 13, 2015 05:08PM |
Darathy
The tongue that clips onto the X arn us 3mm short so it doesnt hold onto the armatleast for me
Re: Bowden tube coming out of extruder May 13, 2015 05:17PM |
Re: Bowden tube coming out of extruder May 14, 2015 07:17AM |
Darathy
DOH! , is there a ormerod 2 version?
Re: Bowden tube coming out of extruder May 14, 2015 10:39AM |
How would that help with the bowden tube problem?Quote
ormerod168
You could print and ad Thorsen's Extruder vs gravity defender :-)Quote
Darathy
Erik
Re: Bowden tube coming out of extruder May 14, 2015 12:08PM |
dmould
ormerod168
Darathy
Erik
Dave
Re: Bowden tube coming out of extruder May 17, 2015 10:50AM |
Re: Bowden tube coming out of extruder May 18, 2015 03:56AM |
Treito
iamburny
Is this version for a M5 nut?
I am afraid that this problem effects me too but I need to know which pneumatic connector I have to buy.
Re: Bowden tube coming out of extruder May 18, 2015 04:09AM |
Re: Bowden tube coming out of extruder May 18, 2015 05:50AM |
That's pretty much the reason we don't use them. We did have them on the original Huxley printer (over 4 years ago...) but found they eventually pop out, too! Which is why we went for a cheaper solution, that is generally more reliable. PTFE is just rather slippery...Quote
dc42
Please note that the pneumatic connectors lose their grip after you have removed and replaced the Bowden tube several times. So get plenty of spare connectors, and only remove the Bowden tube from the connector when you have to.
Re: Bowden tube coming out of extruder May 18, 2015 06:53AM |
Re: Bowden tube coming out of extruder May 18, 2015 12:27PM |
droftarts
dc42
Ian
RepRapPro tech support
Re: Bowden tube coming out of extruder May 18, 2015 02:10PM |
VortyZA
Treito
iamburny
Until I get around to posting on Thingiverse, this is the M5 version with the larger feed diameter, pneumatic screw fit and the PTFE pipe through the feed path to the hobbed insert.
[dl.dropboxusercontent.com]
Once I post it on Thingiverse I'll remove this link
Re: Bowden tube coming out of extruder May 27, 2015 05:08PM |
droftarts
dc42
Ian
Re: Bowden tube coming out of extruder June 05, 2015 02:52PM |
Re: Bowden tube coming out of extruder September 21, 2016 04:43AM |
Re: Bowden tube coming out of extruder September 24, 2016 11:26AM |
Re: Bowden tube coming out of extruder January 08, 2017 04:02AM |
