firmware feature request - help stop blocked nozzles March 03, 2015 05:14AM |
Re: firmware feature request - help stop blocked nozzles March 03, 2015 07:32AM |
appjaws1
I had a problem with a blocked nozzle the other day. I think it was caused by the hotend being up to temperature but not printing , for an extended time. I realised, after getting the printer ready to print, that I needed to modify the item, this took some time to change it in openscad, generate the stl and then slice. All this time the plastic in the hotend was cooking.
I wonder if it is feasible to have the firmware reduce the hotend temperature, after a fixed period of time, if a print has not been started.
might save others from having to clean out a blocked nozzle.
Re: firmware feature request - help stop blocked nozzles March 04, 2015 04:43AM |
Re: firmware feature request - help stop blocked nozzles March 04, 2015 04:58AM |
Re: firmware feature request - help stop blocked nozzles March 04, 2015 06:34AM |
Re: firmware feature request - help stop blocked nozzles March 04, 2015 07:10AM |
pandionx
Personally I've left my hot end on with PLA for well over 45 minutes without any issue.
Re: firmware feature request - help stop blocked nozzles March 04, 2015 07:19AM |
dc42
I'm trying to work out a specification of the required behaviour.
1. Is this only a problem with ABS, or does PLA also cause problems if left molten for too long?
2. What should be the trigger for reducing temperature? E.g. extruder temp greater then X for the last Y seconds, and no extruder motion during that period.
3. What temperature should the extruder be reduced to when this feature is triggered?
4. Should we warn the user that the temperature has been reduced, if so, how?
5. Should we rely on the user to reset the temperature before printing, extruding etc.? If not, under what conditions should we reset the temperature to its previous value?
That is encouraging, as I said in the original post I'm not sure what happens to ABS or PLA if left molten for any length of time. Do we have any experts who could provide an insight?Quote
pandionx
Re: firmware feature request - help stop blocked nozzles March 04, 2015 08:39AM |
Re: firmware feature request - help stop blocked nozzles March 05, 2015 01:16PM |
Re: firmware feature request - help stop blocked nozzles March 06, 2015 07:18AM |
shadow651
Sounds like this often happens before a print is started, maybe setting up end g-codes to retract the filament would prevent a lot of this?
