None of the motor will move! March 15, 2015 09:46AM |
Re: None of the motor will move! March 15, 2015 10:16AM |
Re: None of the motor will move! March 15, 2015 01:28PM |
Re: None of the motor will move! March 15, 2015 02:35PM |
Re: None of the motor will move! March 15, 2015 06:06PM |
Re: None of the motor will move! March 16, 2015 05:01PM |
Re: None of the motor will move! March 16, 2015 06:14PM |
Re: None of the motor will move! March 17, 2015 02:53AM |
dc42
Are you quite certain that the bed and the hot end heat up? Have you checked that the 12V input screw terminals are tight?
It might be worth trying different firmware, e.g. my 1.00o release, zombiepantlol's latest release, or RRP 0.78c - just in case there is an issue in that firmware release that I am not aware of.
Re: None of the motor will move! March 17, 2015 05:39AM |
Re: None of the motor will move! March 17, 2015 10:18AM |
Re: None of the motor will move! March 17, 2015 04:51PM |
dc42
That sounds to me that the firmware is crashing and the software watchdog is resetting the printer. Please do the following:
1. After this has happened, reconnect the web interface or Pronterface. Then run M122 and see what the last reset reason and software reset code are.
2. Try version 1.00o to see if it does the same thing.
Re: None of the motor will move! March 17, 2015 06:03PM |
Re: None of the motor will move! March 18, 2015 06:40AM |
