New firmware 1.04a-dc42 March 21, 2015 11:14AM |
1. Fixed bug in version 1.00q: when uploading to SD card via USB the file was printed immediately.
2. Merged RRP's 1.04 changes:
(a) Implemented automatic control of the fan pin for extruding/non-extruding moves; except that in my fork, this is only enabled if the ancilliary PWM set by M571 is nonzero. This is so that you can still use M106 to control the fan.
(b) Added M573 command to report average heater PWM.
Re: New firmware 1.04a-dc42 March 24, 2015 08:43AM |
Changed tool numbers to start at T0 in all /sys files
Added sample macro files
Improved speed of integer square root function (thanks dmould)
Fixed bug in GCodeBuffer IsEmpty function (thanks zombiepantslol)
Re: New firmware 1.04a-dc42 March 27, 2015 01:55PM |
Re: New firmware 1.04a-dc42 March 27, 2015 03:22PM |
Re: New firmware 1.04a-dc42 March 27, 2015 05:18PM |
Re: New firmware 1.04a-dc42 March 27, 2015 05:39PM |
Re: New firmware 1.04a-dc42 March 27, 2015 05:46PM |
Re: New firmware 1.04a-dc42 March 27, 2015 06:06PM |
Re: New firmware 1.04a-dc42 March 27, 2015 06:08PM |
Re: New firmware 1.04a-dc42 March 27, 2015 06:39PM |
M208 X212 Y210 ; set axis maxima M208 X-8 Y0 S1 ; set axis minima
Re: New firmware 1.04a-dc42 March 27, 2015 07:03PM |
Re: New firmware 1.04a-dc42 March 27, 2015 07:09PM |
Re: New firmware 1.04a-dc42 March 28, 2015 08:01AM |
Re: New firmware 1.04a-dc42 March 28, 2015 08:26AM |
Re: New firmware 1.04a-dc42 March 28, 2015 08:46AM |
Re: New firmware 1.04a-dc42 April 08, 2015 07:38AM |
Re: New firmware 1.04a-dc42 April 08, 2015 09:42AM |
Re: New firmware 1.04a-dc42 April 08, 2015 12:55PM |
Re: New firmware 1.04a-dc42 April 08, 2015 02:31PM |
mynamesriz
That did the trick!
I had to connect the endstop to the E0 terminal rather than the Z terminal but that's it.
Re: New firmware 1.04a-dc42 April 08, 2015 02:52PM |
Re: New firmware 1.04a-dc42 April 08, 2015 03:10PM |
mynamesriz
BTW, the reason for the upgrade was so I could use the Paneldue board I bought recently with it... It's working a treat now, thank you for all the hard work and support.
