Differential IR sensor and BuildTak March 22, 2015 07:42AM |
Re: Differential IR sensor an BuildTak March 22, 2015 08:15AM |
Re: Differential IR sensor an BuildTak March 22, 2015 01:45PM |
Spaceskater
I can confirm that my single nozzle board works fine with BuildTak. I have noticed though that the trigger hight might not be exactly the same with my kapton covered bed.
Re: Differential IR sensor and BuildTak March 23, 2015 08:55AM |
Re: Differential IR sensor and BuildTak March 23, 2015 09:12AM |
dmould
While I don't know what the case is with the BuildTak material, it is worth bearing in mind that colours that look dark or even jet-black under visible light may reflect IR well.
Re: Differential IR sensor and BuildTak March 24, 2015 03:40AM |
Re: Differential IR sensor and BuildTak March 24, 2015 04:01AM |
Re: Differential IR sensor and BuildTak March 24, 2015 04:24AM |
dmould
While I don't know what the case is with the BuildTak material, it is worth bearing in mind that colours that look dark or even jet-black under visible light may reflect IR well. I once had a monochrome camera that automatically switched to IR below a certain visible light level, and I recall seeing black clothing magically changing to white as the IR function cut in - it looked very strange because nothing else in the image changed appreciably. The camera could also see through black Perspex as if it were 100% clear. The Perspex was so opaque that you could look directly at the Sun through it quite comfortably, which brought home the point that using such ad-hoc material to view the Sun (or welding arcs) is dangerous as your retina would be hit with the full amount of the Sun's IR output without you realising it, which I should think would cause a lot of damage in a pretty short time.
Dave
Re: Differential IR sensor and BuildTak March 24, 2015 05:07AM |
jamesf
Black objects are generally good emitters of IR as well as great absorbers, so you are not only seeing reflected IR, but emitted IR produced after absorbance of IR and other wavelengths. (as far as I know ;-) )
James
Re: Differential IR sensor and BuildTak March 24, 2015 08:36AM |
Re: Differential IR sensor and BuildTak March 24, 2015 09:01AM |
Re: Differential IR sensor and BuildTak March 26, 2015 02:21PM |
Re: Differential IR sensor and BuildTak March 28, 2015 09:09AM |
Re: Differential IR sensor and BuildTak March 28, 2015 10:05AM |
Re: Differential IR sensor and BuildTak March 28, 2015 11:03AM |
