The Boiling Frog April 11, 2015 12:39PM |
Re: The Boiling Frog April 11, 2015 02:26PM |
Re: The Boiling Frog April 11, 2015 02:43PM |
Re: The Boiling Frog April 11, 2015 03:00PM |
fotomas
It is my understanding that acetone do not work on PLA. Is that PLA?
Re: The Boiling Frog April 11, 2015 03:09PM |
Yella3D
That's really nice Erik.
I don't print as much ABS as I should, I can't stand the fumes!
Re: The Boiling Frog April 11, 2015 04:40PM |
Re: The Boiling Frog April 12, 2015 06:43AM |
Re: The Boiling Frog April 12, 2015 08:16AM |
Re: The Boiling Frog April 12, 2015 10:33AM |
BenBB
Can you maybe publish the settings for this frog;
Lots of Q`s
Did you use Pronterface or the WEB interface, did you print from SD
Did you use slic3r or some other app. to generate the G-Code...
What base did you use to print on, on glass direct, kapton etc..
Is this a stock standard Ormerod or is it modified in any way ?
If you used pronterface can you publish the setting, not the frog G file settings, as I find that the comments are quite confusing and sometimes one cannot relate them to the actual pronterface entries
VERY IMPORTANT what temperatures did you run the bed ?
Then did you pour the acetone on the printer bed, cover it and left it or soaked the cardboard and then set the heat up to 50degC
Re: The Boiling Frog April 12, 2015 10:47AM |
Re: The Boiling Frog April 12, 2015 12:45PM |
Re: The Boiling Frog April 12, 2015 12:58PM |
Re: The Boiling Frog April 12, 2015 02:19PM |
BenBB
Please see the pic, what else have you done to the OR hotend ? what is that white piece protruding there
Re: The Boiling Frog April 13, 2015 12:19AM |
Re: The Boiling Frog April 13, 2015 01:10PM |
BenBB
... and with the DC42 backwash plate even less air...
Re: The Boiling Frog April 13, 2015 01:19PM |
Re: The Boiling Frog April 28, 2015 04:03PM |
Re: The Boiling Frog April 29, 2015 10:54AM |
Jon Steward
I've tried dipping an ABS print directly into acetone.
Only needs a few seconds.
The gopro holder didn't really work as the walls are quite thin.
Re: The Boiling Frog April 29, 2015 01:22PM |
dmould
.. I soak a paper towel in acetone and just rub it over the surface of the part, which smooths it and helps bond the layers without soaking in and making the ABS go rubbery.
Dave
Re: The Boiling Frog April 29, 2015 02:34PM |
ormerod168
dmould
Dave
will have to try that, would think it would be safer to use a brush, don't you risk getting small bits of paper in the surface that way?
Erik
Re: The Boiling Frog April 29, 2015 03:06PM |
