Printer simply stops, DC42 v104e April 12, 2015 11:55AM |
Re: Printer simply stops, DC42 v104e April 12, 2015 02:02PM |
Re: Printer simply stops, DC42 v104e April 13, 2015 02:24AM |
Re: Printer simply stops, DC42 v104e April 13, 2015 04:06AM |
Re: Printer simply stops, DC42 v104e April 13, 2015 10:06AM |
Re: Printer simply stops, DC42 v104e April 13, 2015 03:24PM |
Re: Printer simply stops, DC42 v104e April 19, 2015 12:41PM |
Re: Printer simply stops, DC42 v104e April 20, 2015 08:35AM |
BenBB
Hi Dave
OK I think I found the issue, yes indeed it is a combination of Slic3r then pronterface
Slick3r exports the file to a Gcode file, but now I see that sometimes it takes a while to export to Gcode then it seems while it is still exporting and I load the file in Pronterface it only loads partially
Hence only part of the file is loaded and hence uploaded to the SD card
Then it only prints the part that was loaded....
So it seems with big file one MUST HAVE PATIENCE ! to upload via Pronterface
Tx Ben
Re: Printer simply stops, DC42 v104e April 20, 2015 08:48AM |
dmould
BenBB
Hi Dave
Tx Ben
I have made that mistake as well. Slic3r can take a long time to export the file. In fact if you have "Do not cross perimeters" checked, some STLs can take many hours to export the file (unless that has been fixed in later releases). It is a good idea to check the print file with a text editor to ensure it has the expected ending (your custom end code etc.)
Dave
Re: Printer simply stops, DC42 v104e April 20, 2015 09:16AM |
shadow651
dmould
BenBB
Hi Dave
Tx Ben
Dave
Another option is to open your gcode in something that can preveiw gcodes, personaly I use Repeater-Host [www.repetier.com] solely for the purpose of looking at the gcode and visualizing non-print moves
Re: Printer simply stops, DC42 v104e April 20, 2015 01:35PM |
dmould
shadow651
dmould
BenBB
Hi Dave
Tx Ben
Dave
The latest Slic3r release has a preview option. One issue with the repetier preview is that it does not correctly display the extrusion width. This can result in the preview incorrectly showing the infill not reaching the perimeter, when in fact it will print OK.
Dave
Re: Printer simply stops, DC42 v104e April 20, 2015 02:33PM |
Re: Printer simply stops, DC42 v104e April 20, 2015 03:41PM |
Re: Printer simply stops, DC42 v104e April 21, 2015 08:03AM |
shadow651
I thought filament width was something given in all the info slic3r dumps into comments, but maybe I'm mistaken.
