Important notice for Ormerod 2 and Huxley Duo owners using PanelDue April 16, 2015 01:36PM |
The touch panel displays draw significant current from the +5V rail. The on-board switching regulator on the Duet can easily handle this. However, the linear regulator on the separate 5V regulator board used on the Ormerod 2 and Huxley Duo may not handle the additional load without additional heatsinking. Therefore, the first thing you should do [after installing PanelDue] is to monitor the temperature of the 5V regulator (the big chip on the 5V regulator board, with a black body, a metal tab at one end and 3 legs at the other end). If it is too hot to touch, then you should fit a heatsink to the regulator, screwed to the metal tab. Important: make sure that the heatsink and fitting screw cannot short against the enclosure, or anything else!
Re: Important notice for Ormerod 2 and Huxley Duo owners using PanelDue April 16, 2015 04:28PM |
Re: Important notice for Ormerod 2 and Huxley Duo owners using PanelDue April 16, 2015 04:43PM |
Fpex
Would a fan work also?
Re: Important notice for Ormerod 2 and Huxley Duo owners using PanelDue April 16, 2015 07:33PM |
dc42
Fpex
A fan increases the rate of heat transfer to the environment, so a fan is a good way of increasing the efficiency of a heatsink. From the pictures on the RepRapPro site, it looks to me that there is no heatsink as such on the regulator board, but there has been an attempt to use the PCB to carry some of the heat away from the regulator. I can't tell whether there is efficient heat transfer between the regulator and the PCB or not - for example, whether the back of the regulator is in direct contact with the copper of the PCB. If there is efficient heat transfer between the regulator and the PCB, then a fan would indeed help.
Re: Important notice for Ormerod 2 and Huxley Duo owners using PanelDue May 24, 2015 12:38PM |
Re: Important notice for Ormerod 2 and Huxley Duo owners using PanelDue May 24, 2015 01:26PM |
coogrrr
Wouldn't it make sense then to provide external power to the PanelDue? I am using an external PC power supply with a Duet and Duet4 Expansion. I want to add the PanelDue now and was thinking to power it off the 5V rail of the power supply. This would remove the added load from the Duet completely and allow me to switch on the both systems with one power switch.
Thoughts?
