Re: New firmware 1.08e and Duet Web Control 1.06 May 02, 2015 07:08AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 02, 2015 07:24AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 02, 2015 08:04AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 02, 2015 09:42AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 02, 2015 11:10AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 03, 2015 12:37PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 03, 2015 12:44PM |
PaulHam
I have just flashed firmware RepRapFirmware-1.04f-dc42.bin (previously been running RepRapFirmware-078t-dc42.bin on my old ormerod (1) without issues)
I have also put the ZPL web interface on the SD card.
When i connect to the webserver and try to home all axis the Y axis runs into the microswitch and gets stuck. It seems that the bed moves in the wrong direction even when commanding it to move from the web interface.
There must be a easy solution that i am overlooking?
Re: New firmware 1.08e and Duet Web Control 1.06 May 03, 2015 12:46PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 03, 2015 12:51PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 04, 2015 07:33AM |
zombiepantslol
If you choose dc42's firmware fork, it's a good idea to replace the homing files with his ones (they allow simultaneous X+Y homing and don't contain any G92 codes that could mess with axis minima). You can keep your current config file though, just add the M574 code as seen in his firmware thread. I'm not aware of any other changes you need to perform if you upgrade to 1.04f-dc42.
Re: New firmware 1.08e and Duet Web Control 1.06 May 10, 2015 02:31PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 10, 2015 02:49PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 11, 2015 02:39AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 11, 2015 03:03AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 11, 2015 04:35AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 12, 2015 03:51AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 20, 2015 01:43PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 07:10AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 07:33AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 08:11AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 11:36AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 12:08PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 12:39PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 01:44PM |
I fixed just that problem by removing some 500 megs of logs from a notes /data/log directory.Quote
Radian
..... Note hasn't got enough memory for it.
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 01:57PM |
auser
Radian
Sadly this requires rooting the device. Som links that may help
Rootin an original note: [www.theandroidcop.com]
Deleting logs second answer here:[stackoverflow.com]
hth
Open the phone app and switch to keypad.
Dial *#9900#
On the screen that appears, click on the button labelled "Delete dumpstate/logcat".
Re: New firmware 1.08e and Duet Web Control 1.06 May 21, 2015 02:06PM |
Radian
Amazing isn't it shadow651. Tech stuff becomes a "Legacy item" while you're unboxing it these days
Re: New firmware 1.08e and Duet Web Control 1.06 May 22, 2015 04:06PM |
Radian
Has anyone tried accessing Duet Web Control 1.06 from an Android smartphone/tablet? I tried a Samsung Galaxy note, a galaxy tablet and an ancient Archos tablet. So cool to be able to do this but all three showed exactly the same problem rendering the Head Movement controls:
[attachment 54969 DWC_Android.png]
I know the browsers in these things are pretty basic but so much renders correctly I was just curious to know if it was perhaps an easy fix.
Re: New firmware 1.08e and Duet Web Control 1.06 May 23, 2015 11:21AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 23, 2015 12:17PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 23, 2015 02:46PM |
