Re: New firmware 1.08e and Duet Web Control 1.06 May 23, 2015 03:02PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 23, 2015 05:08PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 24, 2015 09:00AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 24, 2015 09:11AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 27, 2015 12:41PM |
zombiepantslol
I haven't experienced this white page problem once, so I can't fix what I can't reproduce. If anyone provides a Wireshark capture though, I'll look through it again.
As said earlier Android's stock browser is no longer supported, so either try out Firefox or Chrome if it's supported on your device. I did receive an Android WebView update a few days ago on my Lollipop phone, but I don't have the stock browser on it either.
Re: New firmware 1.08e and Duet Web Control 1.06 May 29, 2015 05:24PM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 31, 2015 11:41AM |
Re: New firmware 1.08e and Duet Web Control 1.06 May 31, 2015 06:55PM |
Treito
And I have one question. I like the option to change the spools. But the motor stays on. I am not able to remove the last piece and more important after changing the spool you should turn the extruder gear until the filament is inside the PTFE tube. If I am turning off the motor my homing positions get lost and so it is difficult (I have a method) to change the spool during printing.
Re: New firmware 1.08e and Duet Web Control 1.06 June 03, 2015 11:02AM |
Re: New firmware 1.08e and Duet Web Control 1.06 June 03, 2015 12:28PM |
Darathy
I have upgraded to dc42's 1.09a and since then the webinterface does not show Print duration and the graph for layer duration does not work properly anymore. The line always stays at 0s. I am using your 1.06 webinterface.
Re: New firmware 1.08e and Duet Web Control 1.06 June 03, 2015 12:44PM |
i just tried an old gcode that i was sure it worked before ,it is the same ,i did notice that all my settings were gone ,i had my own temps inserted and fan sliders enabled and after upgrade they were gone ,i will try to reload sd card files and see what happens ,mybe something went wrong with the SD card.Quote
dc42
Darathy
Strange, it works for me and I am using almost exactly the same PrintMonitor code as in the official RRP release. Is this a gcode file that was definitely working with the firmware you were using previously?
Re: New firmware 1.08e and Duet Web Control 1.06 June 03, 2015 12:59PM |
Re: New firmware 1.08e and Duet Web Control 1.06 June 03, 2015 01:19PM |
Re: New firmware 1.08e and Duet Web Control 1.06 June 07, 2015 10:33AM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 08:58AM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 12:08PM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 12:41PM |
usen
I am a Duet 0.8.5 user. The webinterface is very nice, congratulations! However, I want to say do you add an option for "Restart" button in webinterface. Because we must click the Emergency Stop to stop the printing when we face a problem with printing part. Then, all heaters (nozzle and heated bed) stop and temperatures decrease. "Pause" button can be used for this purpose, but pause enables us to continue where printing stops and then go on same direction. We want to start begining of the printing without shut down the heaters with "Emergency Stop" or "Pause".
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 01:10PM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 04:02PM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 04:19PM |
T-1 M144
Re: New firmware 1.08e and Duet Web Control 1.06 November 09, 2015 06:24PM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 10, 2015 04:16AM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 10, 2015 07:05AM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 11, 2015 07:24AM |
Re: New firmware 1.08e and Duet Web Control 1.06 November 11, 2015 08:05AM |
Unreal.2K7
Thank you for the update! I wish to point out that the wiki [reprap.org], the config.g file [github.com], and probably somewhere else is reported like that too, that the I parameter for the M906 command for setting the motors idle current expects values from 0 to 100 [github.com], while instead the default config.g file passes a value from 0 to 1. This effectively sets the idle current to less than 1%.
