Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 05:45AM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 12:33PM |
zombiepantslol
Hi John,
that code looks quite horrible! First, it's a bad idea to use M25 in G-code files, the right code for this purpose is M226. Second, you should not put it in the same line as a G1 code, put in a separate line either above or below your move code - then it should work well. M25 may be used only to pause a print via the web interface or from a serial line (Pronterface, Simplify3D or dc42's PanelDue). If you modify your G-code file this way, everything should work properly.
Edit: And don't attempt to call M25/M226 in either pause.g or resume.g, this really wouldn't make sense and might cause the symptoms you described.
Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 02:00PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 04:28PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 06:30PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 25, 2015 07:22PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 05:01AM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 12:37PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 01:02PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 03:34PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 04:22PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 04:55PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 05:11PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 05:44PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 26, 2015 07:04PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 27, 2015 01:46PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 27, 2015 02:47PM |
Darathy
might be a defect in the board?
Re: New firmware 1.08e and Duet Web Control 1.06 April 27, 2015 07:19PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 27, 2015 07:22PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 28, 2015 09:21AM |
Igloo_it
The only problem is that i checked the proximity sensor as x instruction and the result is that I'm around 27 to 33 not like they said, no big value is reported, could this cause the problem? In any case I changed the wire position before to test because on my connector the yellow and green was inverted.
Re: New firmware 1.08e and Duet Web Control 1.06 April 28, 2015 09:24AM |
Igloo_it
I started to build another ormerod (I have four to build) and I'm curious to know what's going on with this. I have attached the phots of the two boards that are a little bit different.
Re: New firmware 1.08e and Duet Web Control 1.06 April 28, 2015 10:56AM |
dc42
Igloo_it
I think you have uploaded the same photo twice - I can't see any difference.
Re: New firmware 1.08e and Duet Web Control 1.06 April 29, 2015 02:58AM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 29, 2015 12:50PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 29, 2015 01:40PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 29, 2015 07:29PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 30, 2015 04:19PM |
Re: New firmware 1.08e and Duet Web Control 1.06 April 30, 2015 06:15PM |
Darathy
if you dont have a SD card in the printer , the motor may not have required power to run it since the Power settings are in the Config file on the sd card(Note: you have to load the files onto the sd card ,it is BLANK).
Re: New firmware 1.08e and Duet Web Control 1.06 May 01, 2015 04:59AM |
zombiepantslol
Darathy
Good point! Can you confirm the SD card is read at startup? See [reprappro.com] - this is very important!
Re: New firmware 1.08e and Duet Web Control 1.06 May 01, 2015 05:42AM |
dc42
zombiepantslol
Darathy
I already got him to run M906 to check that the motor currents were set, see [forums.reprap.org].
