M574 command April 19, 2015 03:41AM |
Re: M574 command April 19, 2015 04:14AM |
Re: M574 command April 19, 2015 05:56AM |
Gcode in config
*** If you have a modulated IR probe with on-board microcontroller, change P2 to P1 in the following
M558 P2 ; Use a simple modulated Z probe (change to P1 for an intelligent Z probe)
Tx BenQuote
Gcode documentation
Example: M558 P0 X1 Y0 Z1
A Z probe may be a switch, an IR proximity sensor, or some other device. This selects which to use. P0 indicates that no Z probe is present. P1 gives an unmodulated IR probe, or any other probe type that emulates an unmodulated IR probe (probe output is an analog signal that rises with decreasing nozzle height above the bed). If there is a control signal to the probe, it is driven high when the probe type is P1. P2 specifies a modulated IR probe, where the modulation is commanded directly by the main board firmware using the control signal to the probe. P3 selects an alternative Z probe by driving the control signal to the probe low. P4 selects a switch (on the Duet, this must be connected to the E0 endstop pins).
Re: M574 command April 19, 2015 06:17AM |
