2nd fan duct for acrylic spacer April 19, 2015 12:24PM |
Re: 2nd fan duct for acrylic spacer April 19, 2015 12:58PM |
Re: 2nd fan duct for acrylic spacer April 19, 2015 02:03PM |
Re: 2nd fan duct for acrylic spacer April 19, 2015 02:40PM |
Re: 2nd fan duct for acrylic spacer April 19, 2015 03:04PM |
shadow651
Ditto to the above!
What size fan would this be using?
Re: 2nd fan duct for acrylic spacer April 19, 2015 03:39PM |
Re: 2nd fan duct for acrylic spacer May 28, 2015 12:31PM |
Re: 2nd fan duct for acrylic spacer May 28, 2015 01:53PM |
shadow651
I finally got around to installing this duct and I've been having some issues.
The Duct consistently sits about 3mm lower than the nozzle. Wondering if anyone else has had this problem and/or come up with a solution. I might have to go for a different cooling duct design. So I'm open to suggestions about other ducts that are known to work.
Re: 2nd fan duct for acrylic spacer May 28, 2015 05:23PM |
Re: 2nd fan duct for acrylic spacer May 28, 2015 05:30PM |
Re: 2nd fan duct for acrylic spacer May 30, 2015 11:38PM |
Darathy
i think you just need to push it in a bit ,it should click into place ,just hold the acrylic at the other side ,but dont put too much force so not to break the acrylic.
this fan duct helps a lot ,but it is only effective from the side its facing ,would be nice to get a duct to blow from all directions.
Re: 2nd fan duct for acrylic spacer May 31, 2015 05:09AM |
shadow651
Darathy
I think that was part of the problem, but I think the head is drooping in the Y direction. I've ordered some 10mm bearings to replace the 9mm one on the X runner.
Maybe my duct didn't print perfect and it won't push onto the acrylic spacer all the way.....or it's the Y droop.... or something else
I'll keep messing around with it to see if I can get it to work any better, but I might just go ahead and try and design a donut ring duct
Re: 2nd fan duct for acrylic spacer May 31, 2015 10:46AM |
Re: 2nd fan duct for acrylic spacer May 31, 2015 12:19PM |
droftarts
The fan duct is here: [github.com]
(I need to add it to the list on the first page of the Ormerod 2 instructions: [reprappro.com] )
This has been tweaked fairly recently, as the acrylic fan spacer was changed, and the fan duct had to change too. So check you have the latest version.
Ian
RepRapPro tech support
Re: 2nd fan duct for acrylic spacer May 31, 2015 03:06PM |
Re: 2nd fan duct for acrylic spacer May 31, 2015 03:39PM |
droftarts
Ian
Re: 2nd fan duct for acrylic spacer May 31, 2015 04:14PM |
Re: 2nd fan duct for acrylic spacer May 31, 2015 04:53PM |
Re: 2nd fan duct for acrylic spacer May 31, 2015 04:58PM |
Darathy
my fan duct was from this post and it fits perfectly, altho i will print thisone couse of more airflow
Re: 2nd fan duct for acrylic spacer June 01, 2015 12:38AM |
Re: 2nd fan duct for acrylic spacer June 01, 2015 04:44AM |
Re: 2nd fan duct for acrylic spacer June 01, 2015 05:23AM |
droftarts
Darathy
Hmm... I wonder if we've managed to ship two different fan spacers with Ormerod. If one fits, I don't think the other one will. I'll try and remember to check tomorrow.
This is the earlier one: [github.com]
This is the current one: [github.com]
Ian
shadow651
well, this newer revision of the duct fits much higher up and seems to work fine for me. I'll use in in an actual print later this week to see how well it works. This jointed dragon's head has been giving me a lot of trouble without cooling [www.thingiverse.com]
The OP didn't have anything about mounting the fan to the duct, but I drilled the duct holes out with a 2.5mm bit and M3 screws self tap into it. I think 30mm would be the right length, but I only had 40mm screws on hand I wound up cutting to length.
Re: 2nd fan duct for acrylic spacer June 01, 2015 08:41AM |
Darathy
thats a really cool dragon ,i will have to make one myself
johneato
Where can I find a dxf/stl of the acrylic fan spacer as used on Ormerod 2
John
Re: 2nd fan duct for acrylic spacer June 01, 2015 02:38PM |
Re: 2nd fan duct for acrylic spacer June 02, 2015 07:18AM |
Re: 2nd fan duct for acrylic spacer June 02, 2015 07:50AM |
Re: 2nd fan duct for acrylic spacer June 02, 2015 07:53AM |
Re: 2nd fan duct for acrylic spacer June 02, 2015 09:19AM |
Darathy
I also Printed this Duct and it does not fit as the old one did. it can bearly hold itself on the acrylic spacer.
Re: 2nd fan duct for acrylic spacer June 02, 2015 09:37AM |
Re: 2nd fan duct for acrylic spacer June 02, 2015 09:49AM |
