New firmware 1.04f-dc42 April 19, 2015 12:32PM |
Speed factor and extrusion factor changes now take effect 1 move earlier
Default feed rate after reset increased to 3000mm/min (it used to be the home feed rate of the Z axis, which was annoyingly slow)
M574 command now accepts E parameter so that active low Z probe switches can be used
Bed compensation is cancelled if Z probe was already triggered at the start of a probe
M20 S2 response now flags directories with a * prefix (for PanelDue)
M408 command introduced as an alternative to M105 S2 and M105 S3 (for PanelDue)
When cold extrusion is prevented, say which tool was affected in the error message
Bug fix: if a drive was turned off manually after going into idle mode, when it was enabled again the current remained at 30%
Bug fix: cold extrusion prevention did not work
Re: New firmware 1.00f-dc42 April 19, 2015 01:53PM |
Re: New firmware 1.04f-dc42 April 19, 2015 02:38PM |
Re: New firmware 1.04f-dc42 May 01, 2015 03:51PM |
Re: New firmware 1.04f-dc42 May 01, 2015 04:42PM |
Re: New firmware 1.04f-dc42 May 02, 2015 07:54AM |
Re: New firmware 1.04f-dc42 May 02, 2015 08:27AM |
Re: New firmware 1.04f-dc42 May 02, 2015 08:37AM |
Re: New firmware 1.04f-dc42 May 02, 2015 09:38AM |
Re: New firmware 1.04f-dc42 May 02, 2015 09:46AM |
Re: New firmware 1.04f-dc42 May 02, 2015 10:27AM |
Re: New firmware 1.04f-dc42 May 02, 2015 05:24PM |
Re: New firmware 1.04f-dc42 May 03, 2015 07:08AM |
Re: New firmware 1.04f-dc42 May 03, 2015 08:52AM |
Re: New firmware 1.04f-dc42 May 03, 2015 10:46AM |
Re: New firmware 1.04f-dc42 May 03, 2015 11:09AM |
Re: New firmware 1.04f-dc42 May 03, 2015 11:36AM |
Re: New firmware 1.04f-dc42 May 03, 2015 12:39PM |
Re: New firmware 1.04f-dc42 May 12, 2015 07:39AM |
Re: New firmware 1.04f-dc42 May 12, 2015 10:00AM |
Crouchy
I have an ormerod 1. I've just upgraded from version 0.78v. config files are straight from your SD-Image folder. Everything appears to be working, except for homing the y axis. It hits the end but doesn't stop. my endstop config line is straight from your document
M574 X0 Y2 Z0 S1 ; set endstop configuration (Y endstop only, at high end, active high)
What am I doing wrong?
Re: New firmware 1.04f-dc42 May 13, 2015 06:35AM |
dc42
Strange, that should work. Can you confirm the following:
1. When you try to home the Y axis, the bed initially moves to the left as seen from the front of the machine, but doesn't stop at the end? If it moves to the right, then most likely your endstop switch has become disconnected, or you are using the wrong homing file.
2. To verify that the M574 line has been seen and processed, send M574 with no arguments. The response should be:
Endstop configuration: X none , Y high end (active high) , Z none
3. Send M558. The response should be:
Z Probe type is 1 on channel 0 with dive height 5.0 and it is used for these axes: X Z
btw in case anyone is wondering when 1.09-dc42 is coming, I built it several days ago but I haven't found time to test it.
Re: New firmware 1.04f-dc42 May 13, 2015 10:15AM |
Re: New firmware 1.04f-dc42 May 13, 2015 02:43PM |
