Chinese E3d Replica problem April 21, 2015 04:41PM |
Re: Chinese E3d Replica problem April 22, 2015 02:54AM |
Re: Chinese E3d Replica problem April 23, 2015 05:14PM |
Re: Chinese E3d Replica problem April 24, 2015 08:34AM |
VortyZA
If it's like the Prusa and the header block and nozzle are different materials (aluminium and brass eg.), then it's important to heat the nozzle up to a little higher than extrusion temperature and carefully tighten the nozzle against the block. This should stop your leaking which occurs because of the different expansion/contraction rates between the metals.
Re: Chinese E3d Replica problem April 25, 2015 07:13AM |
Re: Chinese E3d Replica problem April 28, 2015 01:24PM |
Re: Chinese E3d Replica problem April 28, 2015 04:07PM |
Re: Chinese E3d Replica problem April 28, 2015 04:48PM |
gazoox
This thing is annoying. Still have the problem present, but reduced. PTFE band sealing and tightening on higher temperature. My last option (I think) is to add a nut from top against the heaterblock to add an extra sealing force...
Are there any other ideas?
Re: Chinese E3d Replica problem April 28, 2015 04:57PM |
FatFreddie
gazoox
The seal is down to the surface finish of the two mating surfaces (between the heatbreak and the nozzle) and the quality of the threading - not much you can do about the threading but you could make sure the mating surfaces are flat and clean by rubbing them down with some 800 grit abrasive paper. Ideally putting the paper on a flat surface and holding them in something that will keep them at 90 degrees to the surface or at least threading a nut on as a guide.
Re: Chinese E3d Replica problem April 29, 2015 02:59PM |
Re: Chinese E3d Replica problem April 30, 2015 02:39AM |
