Chinese E3d Replica problem
Posted by gazoox
April 21, 2015 04:41PM
Hello.
I couldn't resist to try those cheap E3d replica hotends..
In comparison to original Ormerod 0,5 and 0,3 I cannot see much difference in quality (so far). The china model has 0,4mm.
Problem: Even after unscrew the heater block and more thighten against the brass nozzle, plastic squeezes out of the upper thread. Every 15 minutes, the top must be cleaned.
Inside the heater block the brass nozzle seem to be tighten against the thread of the upper thread screw.
First I thought: overextrusion. But lowering the filament amount did not work.
Do you think its possible to add a Teflon/PTFE sealing strip (for threads) without burning it? Any other ideas?
open | download - Unbenannt.jpg (133.4 KB)
Re: Chinese E3d Replica problem
April 22, 2015 02:54AM
same happened for me. i used some teflon band to seal up the thread. works fine for now.
April 23, 2015 05:14PM
If it's like the Prusa and the header block and nozzle are different materials (aluminium and brass eg.), then it's important to heat the nozzle up to a little higher than extrusion temperature and carefully tighten the nozzle against the block. This should stop your leaking which occurs because of the different expansion/contraction rates between the metals.
April 24, 2015 08:34AM
VortyZA
This is a step in installing an E3D hot end, [wiki.e3d-online.com] so I wouldn't be surprised if it would be necessary to do it for a replica version.
April 25, 2015 07:13AM
Thanks.. The PTFE sealing helps until now.... It leaking comes back I will use the other method.
April 28, 2015 01:24PM
Keep in mind that the added PTFE will limit your max temp to <327C (melting point of PTFE), however you'd probably have to replace your Thermistor with a thermocouple to go above 300C anyways, and there are very few polymers that need such extreme temperatures.
But I thought I'd mention it.
April 28, 2015 04:07PM
This thing is annoying. Still have the problem present, but reduced. PTFE band sealing and tightening on higher temperature. My last option (I think) is to add a nut from top against the heaterblock to add an extra sealing force...
Are there any other ideas?
April 28, 2015 04:48PM
gazoox
The seal is down to the surface finish of the two mating surfaces (between the heatbreak and the nozzle) and the quality of the threading - not much you can do about the threading but you could make sure the mating surfaces are flat and clean by rubbing them down with some 800 grit abrasive paper. Ideally putting the paper on a flat surface and holding them in something that will keep them at 90 degrees to the surface or at least threading a nut on as a guide.
April 28, 2015 04:57PM
FatFreddie
gazoox
Agreed
That is why the original ones cost a lot more QC is much better. Oh and make sure you heat the whole assembly to at least 285 degrees C before you tighten the lot up.
Doug
April 29, 2015 02:59PM
285°C thats very much. Much more than expected for "heat up little higher than extrusion temperature" hot smiley . Will try....
My previouse target temperature was 250°C..
Edited 1 time(s). Last edit at 04/29/2015 02:59PM by gazoox.
April 30, 2015 02:39AM
gazoox
See The section on tightening the hot end is at the end of the page.
HTH
Doug
