Sourcing hardware April 24, 2015 08:22AM |
Re: Sourcing hardware April 24, 2015 09:13AM |
Re: Sourcing hardware April 24, 2015 09:28AM |
dmould
Maybe off-topic, but I know that a few people are, like myself, looking at designing & building a printer. I was looking at the possibility of using V-slots and wheels instead of ground rods and linear bearings for the axis runners of a coreXY design, and came across this UK website that appears to be a very good source for most of the hardware needed to build your own design, modify or find replacement parts for an existing printer. Having a single source for all the hardware (extrusions, belts, pulleys, fasteners, drive electronics, motors etc.) makes life a little easier.
[ooznest.co.uk]
I have not tried it nor have I any vested interest, just passing on something I found while searching the web. The prices do not look unreasonable.
Dave
Re: Sourcing hardware April 24, 2015 11:13AM |
Re: Sourcing hardware April 24, 2015 11:19AM |
dmould
Yes, I see there are cheaper sites, though it may be better to use a V profile for the runners when building from scratch rather than a profile that is not specifically designed to match the wheels. I suspect that the correct section would be cheaper if bought from a manufacturer (if you can find it listed). However it is often worth paying a bit extra for the convenience of a one-stop shop (and you usually save a bit on the shipping cost to offset the higher price). There are all sorts of things to juggle - what parts could be printed without compromising the strength and accuracy overly much, what machining to outsource and what to do yourself which is connected with what tools to invest in. I'm presently seriously tempted by a combination milling machine & lathe (I don't have either) which is a fairly hefty outlay but I could probably justify it with a little imagination! [www.amazon.co.uk] But then there's the cost of the tools and other stuff that go with it to consider.
I've looked at CNC machines (which I'd prefer), but the affordable ones are very small and don't look particularly strong, so I think it is going to be a chicken-and-egg situation and I'll need to build my own. I did come across a very beefy second-hand CNC machine from a factory sale that I could just about have afforded, but it would have meant knocking a hole in a wall to get it in the house after which it would have pretty much filled the spare room completely, not to mention the need to get a 3-phase supply installed. I don't have a place to put a large garden shed, so I have decided to limit myself to machines that will fit through the front door!
Dave
Re: Sourcing hardware April 25, 2015 09:53AM |
Re: Sourcing hardware April 25, 2015 03:59PM |
dmould
Dave
