Printing with PET April 27, 2015 08:29AM |
Re: Printing with PET April 27, 2015 09:15AM |
Re: Printing with PET April 27, 2015 10:16AM |
dmould
I tried some PET filament over the weekend, it is reputedly stronger than ABS and easier to print so I thought it may be better for my quadcopter parts. It prints OK but I was not too impressed. The part I printed warped a little, which could probably be stopped by experimenting with the bed temperature (I used 60 deg), but shows that it does not have a significant advantage in that respect over ABS (so it is not easier to print with IMO). The infill started to break up at a print speed of 60mm/s so I slowed it down and it was fine - again a bit of experimentation with hotend temperature would probably cure that (I used 210 deg). It prints with a very shiny surface finish, so may look better for ornaments etc. I happened to have a rejected (slightly warped) motor arm printed in ABS, and so I printed the same item in PET so as to compare strength and rigidity. Flexing the parts by hand did not reveal any noticeable difference in rigidity, and bending by hand to destruction needed about the same force for both ABS and PET. The PET delaminated easier than ABS, but that could be due to less than optimum print temperature. Weighing both parts however showed that PET is significantly heavier (more dense), which makes it worse for use in a quadcopter given that there are no significant strength or rigidity advantages AFAICT. PET is more expensive than ABS, which is exacerbated by its higher density (less filament length per kg reel).
Dave
Re: Printing with PET April 27, 2015 12:58PM |
dougal1957
Dave
I have had some success with pet and found that Bed temps were lower than that needed for either PLA or ABS think I used 40 but that the hotend needed to be about the same as ABS in fact think I used 245 and it was fine at that. (I also use Kapton Tape on my bed)
I had no warping or delamination and I could not bend it at all. (It was a fairly small part mind)
I must admit that I haven't done much with it but I do have 3 rolls of ESUN PETG to go at.
Doug
Re: Printing with PET April 27, 2015 01:20PM |
Re: Printing with PET April 27, 2015 01:49PM |
Re: Printing with PET April 27, 2015 01:54PM |
Re: Printing with PET April 28, 2015 12:09PM |
Re: Printing with PET April 28, 2015 02:26PM |
Re: Printing with PET April 28, 2015 03:25PM |
I've used both PLA (Purple) and ABS (Pink) for my Quadcopter.Quote
dmould
Dave
Re: Printing with PET April 29, 2015 10:50AM |
Jon Steward
I think the ABS is a better material for this job as it's more flexible.
I've had a few crashes and both materials seem to stand up OK.
Re: Printing with PET April 30, 2015 02:41AM |
Re: Printing with PET April 30, 2015 08:38AM |
Re: Printing with PET April 30, 2015 01:30PM |
Re: Printing with PET May 21, 2015 05:09PM |
Re: Printing with PET May 21, 2015 05:19PM |
I am just starting out with Quadcopters. From basic physics lowering the CofG is going to make the copter less manageable. As gravity is a minor factor compared to acceleration the optimum CofG must be central on all axes.Quote
dmould
Yes, my present design also has the battery attached by velcro straps to the lower plate (it is loosely based on this design [www.thingiverse.com]) - , though surprisingly I found over various designs that a lower C of G does not make a great deal of difference to the stability in flight. The PIDs need to be set up carefully on the controller, and always use "stability" mode (for MultiWii that's "Horizon" or "Angle" mode). Trying to learn to fly a quad in acro mode is very difficult.
Dave
Re: Printing with PET May 22, 2015 08:10AM |
Ralph.Hilton
I'm working with the version at [www.thingiverse.com] as I use Openscad and it is easier to modify.
