Web Interface by Christian Hammacher
May 12, 2015 03:17PM
Hi guys, I am now using the web interface by ZPL which seems great, except for the drop down lists for active and standby temperatures which do not function, any suggestions please.
Brian
Re: Web Interface by Christian Hammacher
May 12, 2015 03:21PM
i had that problem but he fixed it in his files on github later ,when did u download his interface?
May 12, 2015 03:43PM
Hi Darathy,
A few weeks ago now, I will see if there is a later version, I am using version 1.05 but I have just realized that version 1.06 is available.
Brian
May 12, 2015 04:13PM
Hi Brian,
nowadays the web interface from ZPL is the official version as also the firmware since the first of May 2015. The actual firmware version is 1.09, but I did not get a clue what version of the web interface is the actual one. I did not try it yet, but if I where you I would install the actual version from Reprap directly.
May 12, 2015 04:24PM
Darathy is right, there was a problem with my initial 1.06 webif release, but it's been fixed for quite a while on my GitHub repository.
The official RepRapFirmware 1.09 is practically identical to my firmware fork 1.08e and their web interface is the same as version 1.06, but with some RepRapPro branding elements and an embedded IRC channel.
May 12, 2015 04:35PM
zombiepantslol
Do you will continue your great work at your github or at the github from RepRapPro?
May 16, 2015 08:13AM
Hi there,
whilst"heater temperatures", "machine status", "head movements", etc. work perfectly at my web interface of Christian Hammacher, the extruder control is not reacting at all (thus I can not unload or upload filament). Anybody here who has an idea what could be wrong?
I use firmware 1.09 with an Ormerod.
Markus
May 16, 2015 08:17AM
try heating the HotEnd before unloading the fillament ,i think 110 is the trigger for the extruder. Latest firmware disables extruder at cold HotEnd.
Edited 1 time(s). Last edit at 05/16/2015 08:17AM by Darathy.
May 16, 2015 08:34AM
Heater1 standby (T0) 154,9, o`C. Anyhow, At extruder control are the buttoms "retract/extrude" anyhow greyed out .. . My mistake or a buck?
Markus
P.S. How to include the picture direct into the message w/o attaching it as a separate file?
open | download - Capture.GIF (138.1 KB)
May 16, 2015 08:41AM
When you attach a file there will be a button next to the picture(Create a link in the message).
Try setting the heater to active(by clicking on the heater1) and set temperature there ,i have not tried it with on standby
Edited 1 time(s). Last edit at 05/16/2015 08:41AM by Darathy.
May 16, 2015 08:48AM
Darathy
I know, but that button has never worked for me - clicking on it has no effect whatsoever. It seems to work for other people, so I have no idea what the difference is.
Dave
May 16, 2015 08:51AM
[attachment 54740 DSC_0009.jpg]
It should create something lile this in the message.
May 16, 2015 09:17AM
Treito: Yes, I'll continue my work smiling smiley I'm glad to hear you like it.
Darathy is right, you must select a tool before you can extrude or retract filament (clicking on Heater 1 will do so), and heat it up to more than 90°C to retract filament and to at least 160°C to extrude filament. You can disable the temperature check by sending "M302 P1", after a few seconds the feed buttons should become enabled. However, in your case it looks like you haven't selected a tool (hence Heater 1 is in standby mode), so either send "T0" first or click on "Heater 1" to activate it.
May 16, 2015 10:54AM
Yes, yes, yes!!! Thank you very much to all of you. You made me happy smiling smiley
Markus
May 16, 2015 12:16PM
dmould
Darathy
Dave
Hi Dave,
I have had the same issue and found that chrome or Firefox worked but I could never get IE to work.
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
May 17, 2015 07:02AM
appjaws1
dmould
Darathy
Dave
Hi Dave,
Thanks. I'll give one of those a try next time I have a picture to post.
Dave
May 18, 2015 06:49AM
Hi Appjaws1,
How do you get on with Simplify3D? do you print from it direct, I ask because I was thinking of buying a copy but they do not offer a trial version and it is rather expensive.
Brian
May 18, 2015 07:13AM
Simplyfy3d is a good piece of software and provides, probably the best support options. All of my g codes are generated using simplify3d, one of the big advantages is the fact that the g codes are generated really fast.
I use the web interface provided by zpl to control the ormerod.
Hope that helps
May 18, 2015 07:25AM
Thanks for your quick response, so you use Simplify 3D as your slicer and then presumably copy to files to the SD card. Do you think you get a better quality print using Simplify3D and is there a print settings profile available for the Ormerod 2 ?
I apologise for all the questions.
Brian
May 18, 2015 08:17AM
You need to set up the printer parameters for the Ormerod, there is no supplied profile but it is very straightforward and you only need do it once. I use S3D, and the main advantage of S3D is the way you can control support - if you do not do many prints that require support it is probably not worth the outlay for hobbyist use because the latest Slic3r includes most of the other advantages that S3D had compared with Slic3r (but Slic3r makes lousy support structures). The other advantage is that being a commercial product it has an official technical support line and generally very few bugs - I became extremely frustrated with the number of bugs in Slic3r that changed from version to version. I do not use the printer control panel of S3D because the web interface is so much better and does not require a USB cable, but I have heard reports that it will not work with the Duet. Copying files to the SD card using the web interface is simply a matter of drag & drop. It is not a good idea to print direct over USB whatever application you use because of the high probability that the G-codes will not be sent fast enough, causing the printer to pause at intervals and leave blobs on the print. It is not a question of the speed of the USB link (which should be fast enough) but the fact that the OS drivers and USB root hubs can introduce occasional pauses in the USB data stream, especially if you do not have a fast, multi-core CPU.
Dave
May 18, 2015 11:55AM
Thank you Dave, a very comprehensive explanation. I think you are right about the advantage of printing from the web interface which I use and then print direct from the SD card. As to whether I am a hobbyist, I am a telescope engineer for the Norman Lockyer Observatory in Devon. I often need to print parts that I either design or copy for a specific purpose. Simplify3D therefore but possibly not just at the moment.
Brian
May 18, 2015 12:17PM
Europa
Brian
The price of S3D is peanuts for most companies, and IMO well worth the cost in the man-hours it will occasionally save re-printing a print that failed due to a Slic3r bug or getting technical support when it does not behave as expected, and also the ability to print parts that require extensive support. I found that the support columns generated by S3D do their job very well, but practically fall off after the print is complete without leaving much of a mark. For company use therefore I would say that it is well worth getting.
Dave
March 28, 2016 09:02AM
EDIT: posted in wrong forum
Edited 1 time(s). Last edit at 03/28/2016 09:10AM by dkaustin.
March 28, 2016 09:11AM
I'm aware of this problem, but unfortunately I cannot reproduce it on my machines, which makes it rather difficult to debug. I need some more info, see [forums.reprap.org].
If you don't want to or cannot do that, I suggest you downgrade to 1.09x-dc42 until the underlying problem has been resolved, but you can keep DWC 1.11 either way - it's designed to maintain backward-compatibility. Also, does it help if you load the web interface in an incognito tab?
