Not homing Z axis. May 15, 2015 08:58AM |
Re: Not homing Z axis. May 15, 2015 01:14PM |
Europa
If I run home all it works just fine, if I home just the Z axis it comes half way along the z axis and then lowers to crash the bed! I have the same G1 X54 Y5 code in both macros, why is the Z macro failing.
Re: Not homing Z axis. May 15, 2015 04:25PM |
Re: Not homing Z axis. May 15, 2015 04:27PM |
Europa
Hi Dave, no if I just click home Z it goes to the wrong position and crashes the bed, if I hit homeall it does both X and Y correctly and then Z correctly and to the right place, X54 Y5. I have not tried homing Z after homing X and Y individually, I am away from home until Sunday evening now but can try it on my return.
Brian
Re: Not homing Z axis. May 15, 2015 06:26PM |
The reason being is that the printer does not know what the bed position is before you home X & Y, so it cannot move the nozzle to the homing position.Quote
Treito
Europa
Brian
Hi Brian,
you cannot home the Z axis before you homed the other axis.
Re: Not homing Z axis. May 16, 2015 05:20AM |
Re: Not homing Z axis. May 16, 2015 05:30AM |
Re: Not homing Z axis. May 16, 2015 06:18AM |
Europa
Hi Dave, that is so strange, I am sure I have been able to home just Z in the past but it may be that the other two axis had already been homed without me realising.
Brian
Re: Not homing Z axis. May 16, 2015 01:26PM |
Re: Not homing Z axis. May 16, 2015 01:36PM |
Europa
Thank you both Daves, it makes sense, one almost needs a safeguard to ensure "home Z" cannot be run before X and Y have been homed. Would it be possible to add code to home Z to check for 0 on both X and Y before homing?
