Re: New experimental firmware 1.09a-dc42 June 12, 2015 03:30PM |
Firefox3D
Yes sorry for derailing, I just wanted to to know exactly how the print quality differs with the newer firmware.
Dario, is the Z support print with the standard 0.5mm head and speed settings?
Re: New experimental firmware 1.09a-dc42 June 12, 2015 03:46PM |
Re: New experimental firmware 1.09a-dc42 June 12, 2015 04:24PM |
dc42
Ormerod187
Hi dc42,
too many quality problems ... back to previous It seems much better.
Hi Dario, what quality problems are you seeing?
I have had a number of users saying that print quality is better using my 1.00 and later firmware, compared to RRP, zpl, and my pre-1.0 series. I have also had some reports that my later versions slow down more when changing direction by less than 90 degrees. This is entirely possible, because my 1.00 and later firmware honours the settings for maximum instantaneous X and Y speed change when changing direction, but the other builds do not.
If you think that slowing down more when changing direction is affecting print quality, then you can always increase the allowed instantaneous X and Y speed change, using the M566 command. In my fork, these do not affect the minimum printing speed.
Re: New experimental firmware 1.09a-dc42 June 12, 2015 07:41PM |
Re: New experimental firmware 1.09a-dc42 June 13, 2015 06:52AM |
dc42
Dario, you could try doubling the M556 X and Y parameters to 1200 to start with.
Re: New experimental firmware 1.09a-dc42 June 13, 2015 07:57AM |
Re: New experimental firmware 1.09a-dc42 June 13, 2015 10:35AM |
dc42
Hi Dario,
1. After some more testing, I've now increased the defaults to X1800 Y1800.
2. I found a bug in the Move code that causes the printer to slow down more than necessary sometimes. It's fixed in the 1.09b release candidate, which you can get at [dl.dropboxusercontent.com].
Re: New experimental firmware 1.09a-dc42 June 13, 2015 01:14PM |
Re: New experimental firmware 1.09a-dc42 June 13, 2015 01:53PM |
dc42
Re: New experimental firmware 1.09a-dc42 June 13, 2015 02:07PM |
Re: New experimental firmware 1.09a-dc42 June 13, 2015 03:49PM |
Firefox3D
..Did you add a stronger better brace to connect the Z to the Y axis?...
Re: New experimental firmware 1.09a-dc42 June 13, 2015 04:14PM |
Re: New experimental firmware 1.09a-dc42 June 13, 2015 05:04PM |
Ormerod187
Hi Erik,
if I remember correctly the taller-one! the strongest! Ormerod
I never understand why you open with "The Stupidly Tall-merod"
I's a good opportunity to print models so high...
Re: New experimental firmware 1.09a-dc42 June 14, 2015 04:24PM |
Re: New experimental firmware 1.09a-dc42 June 14, 2015 04:33PM |
Re: New experimental firmware 1.09a-dc42 June 14, 2015 04:45PM |
Re: New experimental firmware 1.09a-dc42 June 14, 2015 04:48PM |
Firefox3D
If you go higher with the M566 X and Y values can you get other problems - undershoot? or actually break something
Re: New experimental firmware 1.09a-dc42 June 15, 2015 09:23AM |
Ormerod187
Firefox3D
Are you talking about finding the right settings and lost time through failed prints?
No .... 2 days just for waiting the slicing!
Try a statue 350mm. taller with a high definition.... and take a break at sea!
Dario
