A better z lower mount? (Ormerod2)
Posted by Fpex
May 24, 2015 08:27AM
Now that my psu is dead., I need to dismount and remount my ormerod. This gives opportunities to some changes.
My z lower mount is cracked. I focused so far with a 3d doodler :-) and I have printed a new much stronger mount already. But I see that the mount itself is designed on the weak side.
Has anybody thought and tried a better z lower mount?
----- Making the world smarter @ www.xetal.eu
----- Helping entrepreneurs @ www.fralke.com
Re: A better z lower mount? (Ormerod2)
May 24, 2015 08:35AM
I have already replaced 1 Z lower mount other day ,would be nice to have a better printed solution aswell.
I have seen this on Thingiverse: [www.thingiverse.com]
but i have not tried it it says its for ormerod 1 but it is probably same for Ormerod 2.
Edited 1 time(s). Last edit at 05/24/2015 08:37AM by Darathy.
May 24, 2015 09:07AM
I believe those parts are identical. I exchanged the z-lower-mount of my Ormerod 1 a while ago and modified it to use M4x12 cap head screws instead of the countersunk ones, see here: [forums.reprap.org]
May 24, 2015 01:54PM
zombiepantslol
Now I am a little bit afraid. Because I had some issues with my printer at the moment I replace some parts with newer an better one (at the moment I try to print the spring loaded extruder for example) printed in ABS. My z-lower mount is still the original one delivered with my Ormerod 1. Now I am reading that there are maybe stability issues. Normally ABS should be more stable than PLA, shouldn't it?
The most problems I have are indeed the Exxtruder gears. Some gears I have printed in HIPS cannot be used anymore. My Extruder looks really strange at the moment, but I am able to print at the moment until the new extruder is ready. I do not want to risk my original parts because I am printing ABS and some parts already got a little bit weak.
ZPL, maybe it is a problem with these anti vibration stands?
Sorry, for being a little bit off topic.
May 24, 2015 02:03PM
zombiepantslol
The one on thingiverse is a bit beefier but still got the weakness of using countersunk screws
Erik
May 24, 2015 02:55PM
Treito
zombiepantslol
How do you have them positioned? The ones on thingiverse( [www.thingiverse.com] ) ,they say to put them under z motor but appjaws later told me to put it under the Z foot(it was a bit slipery so i put some double sided tape on the vibration absorption thingy) ,i had it under the motor and it probably broke my Z lower mount.
May 24, 2015 03:00PM
I was not able to print them yet. Luckily I have to say. But I heard they should be placed under the motor. So I have to print a new lower mount first. Or is the Ormerod 1 not affected?
May 24, 2015 03:04PM
Heres what appjaws(the creator of the vibration mounts) said in my post:
[forums.reprap.org]
May 24, 2015 03:16PM
So I think that appjaws is right because he designed them. Nevertheless I first have to have some replacement just in case and the design of ZPL seems to be better in my eyes. But I want to have these tiles if the printer is really going to be quieter. I also replaced the fan. The original one was broken after a very short time and the new one is much quieter.
May 24, 2015 03:18PM
If anyone notices that my modified version cracks, please let me know and I'll reinforce it a bit more. So far I'm quite happy with my modded version, though.
May 24, 2015 03:21PM
they make the printer much much quieter ,in fact you can mostly just hear the just fans.
Edited 1 time(s). Last edit at 05/24/2015 03:22PM by Darathy.
May 24, 2015 03:25PM
i also noticed that the countersunk screws are a bit too long(the ones supplied with my printer) in the triangle part i noticed that the scews actualy reached the extrusion before the plastic even came near it. i only noticed after reasembeling it ,i could see circular scratches on the extrusion ,so i shortened them.
May 25, 2015 04:24AM
Darathy
Erik
May 25, 2015 06:19AM
ormerod168
Darathy
[attachment 55286 screws_too_long3.JPG]
Erik
exactly like that
May 25, 2015 06:46AM
Darathy
ormerod168
Darathy
Erik
exactly like that
...and I showed and told Ian RepRapPro that long ago, his answer was "but what can we do about it?, those screws are already out there" - and my answer "been thinking hard about this......how about like...ad a note in the documentation to short those screws?"
Sound of crickets, then nothing :-) - maybe he thinks the mounting of the z-extrusion is rock solid and don't need support from that corner bracket, me think that arrangement is very flimsy and need all the help it can get
Erik
