Slic3r infill/perimeter overlap May 24, 2015 12:11PM |
Re: Slic3r infill/perimeter overlap May 24, 2015 01:31PM |
Re: Slic3r infill/perimeter overlap May 24, 2015 06:31PM |
dc42
Regarding the Lego brick which has two perimeters but no infill between them, that happens when the thickness of the wall is less then three times the extrusion width. I had this problem when I tried to build a 1.5mm thick wall using the default extrusion width - which I think is about 0.6mm for a 0.5mm nozzle. Increasing the wall thickness to 1.8mm solved the problem. Specifying 0.5mm extrusion with would probably have worked too.
Re: Slic3r infill/perimeter overlap May 24, 2015 06:43PM |
Re: Slic3r infill/perimeter overlap May 25, 2015 04:41AM |
Re: Slic3r infill/perimeter overlap May 25, 2015 08:41AM |
