Hi All
I want to find out which wire is best to replace the current kit wire with, it is VERY unreliable, heavy, thick and causes lots of connectivity issues
I found that the wires place a lot of strain on the print head, also the "shielding" on the end are poorly applied. I also found some wires shorting due to poor kit quality...especially where the sheath was stripped. They cut trough the cores and it shorted resulting in a blown DUET !!
I also find the thick core 1.2mm wires are way over kill for driving the steppers..
Is there a silicone shielded 4 core wire available that anyone uses... it must be flexible and more durable that the current kit wires
Otherwise I will make up my own 4 core with better quality wire
Tx Ben
