Ordered 528.4 Opposite hand parts
May 25, 2015 05:59AM
First two parts in my build parts 547 Y idler Brkt & 548 Y motor Brkt are opposite hand to pic's in build instructions on line ? .
Re: Ordered 528.4 Opposite hand parts
May 25, 2015 06:10AM
In subject above should read ormerod my iPad changed it to ordered !.
Re: Ormerod 528.4 Opposite hand parts
May 25, 2015 06:12AM
If these two parts are reversed can I proceed and build an opposite hand Y assembly will this bit me laterer on.
May 25, 2015 06:20AM
Make sure you are reading the correct build instructions for the printer you have. There are two models, the Ormerod1 and the Ormerod2. The Y beds are opposite, so I suspect you may be building from the wrong instructions!
Dave
May 25, 2015 06:46AM
Ormerod 2 instructions: [reprappro.com]
The Ormerod 1 instructions come up first if you google 'ormerod build instructions'.
Ian
RepRapPro tech support
May 25, 2015 08:22AM
Thanks I will check.
May 25, 2015 08:27AM
Thank you are right
May 25, 2015 08:51AM
droftarts
Ian
Might be an idea to add a big warning right at the top of the two instructions, Ian? I did a similar thing in reverse when looking up something a while ago, but am familiar enough with the printer that I realised the mistake immediately.
Dave
