Problems after firmware update (Ormerod 1) May 30, 2015 05:58PM |
; Configuration file for RepRap Ormerod 1
; RepRapPro Ltd
; Copy this file to config.g if you have an Ormerod 1
; If you are updating a config.g that you already have you
; may wish to go through it and this file checking what you
; want to keep from your old file.
; For G-code definitions, see [reprap.org]
M111 S0 ; Debug off
M550 PMichel's Printer ; Machine name (can be anything you like). With DHCP enabled connect to (example) [reprapproormerod1] (machine name with no spaces).
M551 POrmerod ; Machine password (currently not used)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
;M552 P0.0.0.0 ; Un-comment for DHCP
M552 P192.168.1.14 ; IP address, comment for DHCP
M553 P255.255.255.0 ; Netmask
M554 P192.168.1.1 ; Gateway, comment for DHCP
M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
G90 ; Send absolute corrdinates...
M83 ; ...but relative extruder moves
M906 X800 Y1000 Z800 E800 ; Set motor currents (mA)
M569 P0 S1 ; Set X axis direction
M92 E429 ; Set extruder steps per mm
M558 P1 ; Use an unmodulated Z probe (change to P2 if you update to the modulated probe)
G31 Z5.3 P619 ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup)
M556 S75 X0 Y0 Z0 ; Put your axis compensation here
M201 X500 Y500 Z15 E500 ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)
M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute
M563 P1 D0 H1 ; Define tool 0
G10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures
M574 X0 Y2 Z0 S1
Re: Problems after firmware update (Ormerod 1) May 30, 2015 06:11PM |
M563 P1 D0 H1 ; Define tool 0 G10 P1 S-273 R-273 ; Set tool 0 operating and standby temperatures
Re: Problems after firmware update (Ormerod 1) May 30, 2015 06:14PM |
Re: Problems after firmware update (Ormerod 1) May 31, 2015 10:34AM |
